JIRA DVCS Connector
unematiii August 18, 2014
I'm trying to add DVCS Account from "Administration >> Manage DVCS Accounts". I have created the app in GitHub, but when I fill in the form and click 'Add', I'm getting 404
"Oh, it seems that we've lost a page. Maybe you should raise an issue?"
at
http://myjiradomain.com/login/oauth/authorize?scope=repo&client_id=[removed]&redirect_uri=http%3A%2F%2Fmyjiradomain.com%2Fsecure%2Fadmin%2FAddOrganizationProgressAction%21default.jspa%3Furl%3Dhttps%253A%252F%252Fgithub.com%26atl_token%[removed]%7Clin%26organization%3DDWGitHub%26autoLinking%3Dtrue%26autoSmartCommits%3Dtrue%26t%3D2
Do I need to enable some other plugin first?
Edit: Could this be related to https://answers.atlassian.com/questions/135199/integration-between-bitbucket-and-jira-fails-with-a-404?
Tiago Comasseto
August 18, 2014
Hey Mati, you may want to confirm that the Authorization callback URL in your repository configuration is pointing to the same URL you're accessing JIRA.
I hope it helps.
Cheers
Hi! Thanks for quick suggestion. The callback URL is correct. Problem appears to be JIRA related, as it gives 404 for any reqests made to
Tiago Comasseto
August 18, 2014
Interesting, I found this KB article that describe the same issue. You may want to try the suggested workaround. Also, please update DVCS addon to the latest version in case you're not in the last version yet.
Cheers
Tiago Comasseto
August 18, 2014
I'm glad to hear that Mati, if you think this question was answered satisfactorily, you may mark it as answered. This will increase its visibility and may help others in the future.
Cheers
Thank you! Workaround fixed this for us.
