We were told to run the following queries:
INSERT INTO "AO_C3C6E8_RATE_TABLE"
("ID","NAME","CURRENCY_CODE","DEFAULT_TABLE","EFFECTIVE_DATE")
VALUES (1,'Tempo Default Price Table','USD',true,'2003-01-01');
INSERT INTO "AO_C3C6E8_RATE"
("ID","AMOUNT","LINK_ID","LINK_TYPE","RATE_TABLE_ID")
VALUES (1,'0',0,'DEFAULT_RATE',(SELECT "ID" FROM "AO_C3C6E8_RATE_TABLE" WHERE "DEFAULT_TABLE" = true));
And for us MS SQL folks, this worked for us:
SET IDENTITY_INSERT "AO_C3C6E8_RATE_TABLE" ON
VALUES (1,'Tempo Default Price Table','USD',1,'2003-01-01');
SET IDENTITY_INSERT "AO_C3C6E8_RATE_TABLE" OFF
SET IDENTITY_INSERT "AO_C3C6E8_RATE" ON
VALUES (1,'0',0,'DEFAULT_RATE',(SELECT "ID" FROM "AO_C3C6E8_RATE_TABLE" WHERE "DEFAULT_TABLE" = 1));
SET IDENTITY_INSERT "AO_C3C6E8_RATE" OFF
I believe it's related to the fact that I cannot set the team member prices / rates for an account - the relevant Tempo page is blank - the relevant Tempo case is "TCS-3448 Cannot set any value in Price Tables".
Yep, that page is blank here as well but it was on the previous version also.
Same issue here, occurred after upgrading from 8.12.1 to 8.13.1. Removing all Tempo add-ons and reinstalling them, won't help.
Opened a Tempo support issue..
Hello, our JIRA also had to same problem. We reverted back to 8.3.1 to fix this. Please advise when the issue is fixed so we can re-update the add-on.
We have the same issue, any idea about that?
regards
Why issue looks like "Solved?". Where is the solution?
It's a permission issue - for system administrators this error dialog does not show up - which is why I thought it was fixed, for normal users it does.
No idea how to fix, though.
My Tempo ticket has been TCS-3220. They advised that they are unable to reproduce and suggested reinstalling.
I suspect the cause that in addition to the Tempo Timesheets, the Jira had installed also Tempo Core, Tempo Accounts, and 4-5 other Tempo addins which may be left from some old versions.
So what I did:
The error is gone!
The default rate table that is causing this error is a Tempo feature, so yes, when you disable Tempo, the error is no longer there.
We have seen this error before, when Tempo was updated from versions before 8.x without taking the required steps to upgrade (https://tempoplugin.jira.com/wiki/spaces/TT/pages/38797469/Tempo+Timesheets+upgrade+notes).
In most of these cases, uninstalling Tempo and all Tempo System plugins, installling the original version and then updating in the recommended steps, solved the problem.
In case you encounter this problem when upgrading from a recent version of Tempo, please create a ticket in our Tempo support (https://tempo-io.atlassian.net/servicedesk/customer/portal/6) so we can better investigate this.
Please add a screenshots of the Tables and Rows listed for the "System Plugin: Tempo Accounts" (in JIRA Administration, System, Plugin Data Storage) and the JIRA logs of the update.
Susanne Götz
Tempo team
The required steps include migrating first the Tempo and then Timesheets. That however does not look right - on my add-ins there was only ONE button to update, not two buttons.
Furthermore, I have set up automatic updates of plugins which may may not be part of the problem.
I to am having this issue. Upgraded from Timesheets 8.12.1 and Planner 5.0.0 to 8.13.1 and 5.1.1.
I submitted a ticket with Tempo and awaiting assistance.
Same problem here, this solution did not solve the problem but the "Solved Answer", insert SQL works like a charm!
I have created a support case with Tempo and they are looking into this.
They are also aware of this thread.
Thanks to everyone!
Jiri, inform us please about the answer of Tempo support team.
Have you tried any of the resolutions suggested in this thread?
Hi Jiri,
I have the same problem. It is caused by a plugin Tempo.
It's caused by a plugin tempo. If you disable this plug-in and get connected plugins, the error is no longer there.
Have a nice day
