I had the "JIRA Drag and Drop Attachment Plugin" installed and was working great.
But today when I try to use it I discovered the plugin doesn´t appears on the issues.
I checked and it´s enabled on the plugin manager.
If you upgraded to the Drag and Drop plugin version 3.2.5 you will need to enable the dark feature for it to continue to appear. This was noted in the release notes of that version:
You can navigate to this page on your instance: /secure/admin/SiteDarkFeatures!default.jspa
And add the following Dark Feature: jira.plugins.dnd.attachment
It worked like a charm Jacob. Honestly, I did not read the release notes. My bad.
Thank you very much
Nima
Hi
I have the same issue. I am running JIRA 6.3.12. Today, I went to add-on manager and it mentioned that there was an update for the drag and drop plugin. I just updated that and now it has disappeared. I disabled and enabled which didn't help.
I uninstalled and reinstalled and it didn't help either. I think something may be wrong with this version (3.2.5).
Please advise
Best wishes
Nima
My bad. As @Jacob Feisley marked the solution was on the release notes.
Thanks for your time Jacob, that was the solution to the issue
Did you upgrade to JIRA 6.4? Or try to disable and re-enable the add on? Any errors in the log file or JS errors?
Hi @Timothy Chin and thanks for your quick response
My current version it´s JIRA server v6.3.15
I tried disable and re-enable and uninstall and re-install the add on without success
Wich logs should I check (catalina, commons-daemon, host-manager)?
In the atlassian-jira.log
