JIRA Fails to run: Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor]
NickW
Hi All
Our instance of JIRA has suddenly stopped working. When I look in
jira300512101116-stdout.2014-03-20.log
I see the following::
Timer-1 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.jira-importers-redmine-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2014-03-20 08:42:36,049 Timer-1 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.plugins.jira-importers-redmine-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.jira.plugins.importer.tracking.UsageTrackingService)] (from bean [&usageTrackingService]), Dependency on [(objectClass=com.atlassian.jira.plugins.importer.web.ConfigFileHandler)] (from bean [&configFileHandler]), Dependency on [(objectClass=com.atlassian.jira.plugins.importer.imports.importer.JiraDataImporter)] (from bean [&jiraDataImporter])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.jira.plugins.jira-importers-redmine-plugin' has timed out
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105)
at java.util.TimerThread.mainLoop(Unknown Source)
at java.util.TimerThread.run(Unknown Source)
2014-03-20 08:42:36,049 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&usageTrackingService' for plugin 'com.atlassian.jira.plugins.jira-importers-redmine-plugin' with filter (objectClass=com.atlassian.jira.plugins.importer.tracking.UsageTrackingService)
2014-03-20 08:42:36,049 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&configFileHandler' for plugin 'com.atlassian.jira.plugins.jira-importers-redmine-plugin' with filter (objectClass=com.atlassian.jira.plugins.importer.web.ConfigFileHandler)
2014-03-20 08:42:36,049 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&jiraDataImporter' for plugin 'com.atlassian.jira.plugins.jira-importers-redmine-plugin' with filter (objectClass=com.atlassian.jira.plugins.importer.imports.importer.JiraDataImporter)
2014-03-20 08:42:36,049 Timer-1 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin com.atlassian.jira.plugins.jira-importers-redmine-plugin
2014-03-20 08:42:36,064 Timer-1 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugins.jira-importers-redmine-plugin, config=osgibundle:/META-INF/spring/*.xml))
How do I resolve this.....?????
How do I trouble shoot the failure????
Cheers
Nick
NickW
For some reason the importers plugin had become disabled. I think there were dependencies related to this causing the error above. Anyway I re-enabled it and the error went away.
John Sanford
November 5, 2014
How do you do that?
