JIRA - How to add attachment for issues using REST API (PHP)
carol yang March 27, 2014
Hi
I'm now working on attaching attachment for issues based on REST API using PHP. This is my code:
<?php
$ch=curl_init();
$headers = array(
'X-Atlassian-Token: nocheck',
'Content-Type: multipart/form-data'
$data = array("file" => "attachments/test.txt");
curl_setopt_array(
$ch,
array(
CURLOPT_URL=>'http://localhost:8080/rest/api/latest/issue/IS-23/attachments',
CURLOPT_POST=>true,
//CURLOPT_HTTPGET =>true,
CURLOPT_VERBOSE=>1,
CURLOPT_POSTFIELDS=>$data,
CURLOPT_SSL_VERIFYHOST=> 0,
CURLOPT_SSL_VERIFYPEER=> 0,
CURLOPT_RETURNTRANSFER=>true,
CURLOPT_HEADER=>false,
CURLOPT_HTTPHEADER=> $headers,
CURLOPT_USERPWD=>"test:test"
$result=curl_exec($ch);
$ch_error = curl_error($ch);
if ($ch_error) {
echo "cURL Error: $ch_error";
} else {
var_dump($result);
curl_close($ch);
However, I could got any result. Any ideas?
Dmitry Kochnev
June 14, 2017
Hi All,
Just confirmed that it is working well on cURL (PHP 5.6)
public function upd_to($resource, $data, $issueID, $jiraURL, $jiraUserName, $jiraUserPassword)
$ch = curl_init();
curl_setopt_array($ch, array(
CURLOPT_POST => 1,
CURLOPT_URL => $jiraURL . '/rest/api/latest/' . $resource . '/' . $issueID . '/attachments',
CURLOPT_USERPWD => $jiraUserName . ':' . $jiraUserPassword,
CURLOPT_POSTFIELDS => $data,
CURLOPT_VERBOSE => 0,
CURLOPT_RETURNTRANSFER => true,
CURLOPT_HTTPHEADER => array('X-Atlassian-Token: nocheck')
$result = curl_exec($ch);
curl_close($ch);
return json_decode($result, true);
Please pay attention to:
$data = array(
'file' => curl_file_create($filePath)
For PHP 5.5+ we should use "curl_file_create" function instead of:
$upd_issue = array(
'file' => "@" . $filePath . ";filename=" . "TEST.mp3"
Nicholas Ng March 12, 2015
The following code works for me (tested on JIRA version 6.3.12):
&lt;?php
$ch=curl_init();
$headers = array(
$data = array("file" =&gt; "@filepath/filename.png;filename=filename.png");
curl_setopt_array(
    $ch,
    array(
        CURLOPT_URL=&gt;'http://localhost:8080/rest/api/latest/issue/TEST-01/attachments',
        CURLOPT_POST=&gt;true,
        CURLOPT_VERBOSE=&gt;1,
        CURLOPT_POSTFIELDS=&gt;$data,
        CURLOPT_SSL_VERIFYHOST=&gt; 0,
        CURLOPT_SSL_VERIFYPEER=&gt; 0,
        CURLOPT_RETURNTRANSFER=&gt;true,
        CURLOPT_HEADER=&gt;false,
        CURLOPT_HTTPHEADER=&gt; $headers,
        CURLOPT_USERPWD=&gt;"userid:password"
if ($ch_error) {
} else {
    var_dump($result);
curl_close($ch);
?&gt;
Joan Gimenez
March 21, 2017
Worked for me.
Michael Kast
November 3, 2016
Hello, was anybody of you able to solve the problem?
Michael Bulger March 12, 2015
Was a solution ever found for this?
lama saad
October 21, 2014
Hello,you should add  '@' character before the file example :@file.txt and you will have your file attached @carol yang @Nicholas Ng
Nicholas Ng August 27, 2014
I have the same problem adding attachment via PHP REST API. Anybody have any working code example or point to some refernece?
Get Certified! ✍️
