×Hi, I need to let all users get notified for thier changes, I need toi set this value to true in database for all users, by default this value is set to false. user>profile>preferences
This can be achieved using a groovy script that is run in the Groovy Script Runner Plugin panel
import com.atlassian.crowd.embedded.api.User import com.atlassian.jira.ComponentManager import com.atlassian.jira.user.preferences.PreferenceKeys; import com.atlassian.jira.user.preferences.UserPreferencesManager import com.atlassian.jira.user.util.UserUtil import com.atlassian.jira.util.JiraEntityUtils import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.IssueRelationConstants // this script sets flag "notify about own changes" to true for a set of users // change this if you don't want it for all users (jira-users) String do_it_for="jira-users" UserPreferencesManager upm = ComponentManager.getInstance().getUserPreferencesManager() UserUtil userUtil = ComponentManager.getInstance().getUserUtil() SortedSet<User> members = userUtil.getAllUsersInGroupNames([do_it_for]) String result = "Users that will be notified about own changes now:\n" try { members.each() { User user = it prefs = upm.getPreferences(user) prefs.setBoolean(PreferenceKeys.USER_NOTIFY_OWN_CHANGES, Boolean.TRUE); result += "- "+user.getName()+" ("+user.getDisplayName()+")\n" } return result } catch (e) { } // make sure change is visible immediately upm.clearCache() return result
If you want to change the preference for other users, just change the group name in variable do_it_for
Great many thanks!!
Learn more
