×I have figured out how to import via a csv and map the fields, but it seems to be time consuming.
Sam,
JIRA cannot automatically match the column headers when using the CSV importer. It is frustrating and time consuming to match.
If you are using the same file structure for multiple imports, you can save the configuration file after an import. You can upload this file at the beginning of an import to help speed up the process.
Kian
