I get the following exception when running re-index....
Could someone help on how to resolve this issue?
java.lang.NullPointerException at java.util.ArrayList.addAll(Unknown Source) at com.atlassian.jira.issue.index.DefaultChangeHistoryRetriever.filterChangeItems(DefaultChangeHistoryRetriever.java:120) at com.atlassian.jira.issue.index.DefaultChangeHistoryRetriever.createChangeGroupsFromChangeItems(DefaultChangeHistoryRetriever.java:61) at com.atlassian.jira.issue.index.DefaultChangeHistoryRetriever.get(DefaultChangeHistoryRetriever.java:54) at com.atlassian.jira.issue.index.DefaultChangeHistoryRetriever.get(DefaultChangeHistoryRetriever.java:30) at com.atlassian.jira.issue.index.DefaultIssueIndexer$ChangeHistoryDocumentBuilder.get(DefaultIssueIndexer.java:567) at com.atlassian.jira.issue.index.DefaultIssueIndexer$IssueLockDocumentCreationStrategy$2.get(DefaultIssueIndexer.java:597) at com.atlassian.jira.issue.index.DefaultIssueIndexer$IssueLockDocumentCreationStrategy$2.get(DefaultIssueIndexer.java:593) at com.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:315) at com.atlassian.jira.issue.index.DefaultIssueIndexer$IssueLockDocumentCreationStrategy.get(DefaultIssueIndexer.java:592) at com.atlassian.jira.issue.index.DefaultIssueIndexer$IndexIssuesOperation.perform(DefaultIssueIndexer.java:446) at com.atlassian.jira.issue.index.DefaultIssueIndexer$4$1.get(DefaultIssueIndexer.java:284) at com.atlassian.jira.issue.index.DefaultIssueIndexer$4$1.get(DefaultIssueIndexer.java:280) at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:9) at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:5) at com.atlassian.jira.issue.index.DefaultIssueIndexer$4.consume(DefaultIssueIndexer.java:279) at com.atlassian.jira.issue.index.DefaultIssueIndexer$4.consume(DefaultIssueIndexer.java:272) at com.atlassian.jira.issue.util.DatabaseIssuesIterable.foreach(DatabaseIssuesIterable.java:66) at com.atlassian.jira.issue.index.DefaultIssueIndexer.perform(DefaultIssueIndexer.java:271) at com.atlassian.jira.issue.index.DefaultIssueIndexer.indexIssues(DefaultIssueIndexer.java:121) at com.atlassian.jira.issue.index.DefaultIssueIndexer.indexIssuesBatchMode(DefaultIssueIndexer.java:132) at com.atlassian.jira.issue.index.DefaultIndexManager.doIndexIssuesInBatchMode(DefaultIndexManager.java:857) at com.atlassian.jira.issue.index.DefaultIndexManager.doStopTheWorldReindex(DefaultIndexManager.java:827) at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexAll(DefaultIndexManager.java:337) at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexAll(DefaultIndexManager.java:303) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.atlassian.util.profiling.object.ObjectProfiler.profiledInvoke(ObjectProfiler.java:81) at com.atlassian.jira.config.component.SwitchingInvocationHandler.invoke(SwitchingInvocationHandler.java:28) at $Proxy161.reIndexAll(Unknown Source) at com.atlassian.jira.util.index.CompositeIndexLifecycleManager.reIndexAll(CompositeIndexLifecycleManager.java:54) at com.atlassian.jira.web.action.admin.index.ReIndexAsyncIndexerCommand.doReindex(ReIndexAsyncIndexerCommand.java:28) at com.atlassian.jira.web.action.admin.index.AbstractAsyncIndexerCommand.call(AbstractAsyncIndexerCommand.java:54) at com.atlassian.jira.web.action.admin.index.ReIndexAsyncIndexerCommand.call(ReIndexAsyncIndexerCommand.java:16) at com.atlassian.jira.web.action.admin.index.AbstractAsyncIndexerCommand.call(AbstractAsyncIndexerCommand.java:23) at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:366) at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source) at java.util.concurrent.FutureTask.run(Unknown Source) at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source) at java.util.concurrent.FutureTask.run(Unknown Source) at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForTenant(DefaultMultiTenantManager.java:61) at com.atlassian.multitenant.juc.MultiTenantExecutors$WrappedRunnable.run(MultiTenantExecutors.java:160) at com.atlassian.jira.task.ForkedThreadExecutor$ForkedRunnableDecorator.run(ForkedThreadExecutor.java:249) at java.lang.Thread.run(Unknown Source)
Issue solved. We just deleted the null values from db.. Thx
Hi Aris,
Did you try cleaning the cache and work folder as explained here : https://answers.atlassian.com/questions/151453/jira-4-4-5-jira-startup-failed-plugins-did-not-start ?
that might help.
Best regards,
Peter
