JIRA Install hangs when trying to connect to Oracle 11G database
Patrick Toma March 15, 2012
I am trying to install JIRA 5 with an Oracle 11G database. I have filled out my dbconfig.xml file with all of the DB parameters. When I start JIRA, it just hangs at one point saying:
2012-03-14 10:26:14,250 main INFO jira.config.database.DatabaseConfigurationManagerImpl Now running Database Checklist Launcher
The log shows no other errors. Not sure what my next steps should be.
Using the same database parameters, I can connect from my JIRA server to the database using SQLPlus..
bash-3.2$ sqlplus jiradbuser/XXXXXXXX@JIRA01
SQL*Plus: Release 11.2.0.2.0 Production on Thu Mar 15 13:40:44 2012
Copyright (c) 1982, 2010, Oracle. All rights reserved.
Connected to:
Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
With the Partitioning, OLAP, Data Mining and Real Application Testing options
SQL> select sysdate from dual;
SYSDATE
15-MAR-12
SQL>
JIRA starting...
2012-03-14 10:26:13,932 main INFO atlassian.jira.startup.JiraStartupLogger
___ Environment _____________________________
JIRA Build : 5.0#713-sha1:aec58e27a0d402341b1f1be2fc8c0204a0b070f6
Build Date : Wed Feb 15 00:00:00 PST 2012
JIRA Installation Type : EAR/WAR
Application Server : Apache Tomcat/6.0.35 - Servlet API 2.5
Java Version : 1.6.0_18 - Sun Microsystems Inc.
Current Working Directory : /apps/jira-home/log
Maximum Allowable Memory : 455MB
Total Memory : 122MB
Free Memory : 87MB
Used Memory : 35MB
Memory Pool: Code Cache : Code Cache: init = 2555904(2496K) used = 1244672(1215K) committed = 2555904(2496K) max = 50331648(49152K)
Memory Pool: PS Eden Space : PS Eden Space: init = 33554432(32768K) used = 32134400(31381K) committed = 33554432(32768K) max = 167772160(163840K)
Memory Pool: PS Survivor Space : PS Survivor Space: init = 5570560(5440K) used = 2311752(2257K) committed = 5570560(5440K) max = 5570560(5440K)
Memory Pool: PS Old Gen : PS Old Gen: init = 89522176(87424K) used = 2341696(2286K) committed = 89522176(87424K) max = 357957632(349568K)
Memory Pool: PS Perm Gen : PS Perm Gen: init = 21757952(21248K) used = 18665144(18227K) committed = 21757952(21248K) max = 268435456(262144K)
JVM Input Arguments : -Djava.util.logging.config.file=/apps/tomcat/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Xms128m -Xmx512m -XX:MaxPermSize=256m -Djava.endorsed.dirs=/apps/tomcat/endorsed -Dcatalina.base=/apps/tomcat -Dcatalina.home=/apps/tomcat -Djava.io.tmpdir=/apps/tomcat/temp
___ Java System Properties _________________
catalina.base : /apps/tomcat
catalina.home : /apps/tomcat
catalina.useNaming : true
common.loader : ${catalina.base}/lib,
${catalina.base}/lib/*.jar,
${catalina.home}/lib,
${catalina.home}/lib/*.jar
file.encoding : UTF-8
file.encoding.pkg : sun.io
java.awt.graphicsenv : sun.awt.X11GraphicsEnvironment
java.awt.printerjob : sun.print.PSPrinterJob
java.class.version : 50.0
java.home : /usr/java/jdk1.6.0_18/jre
java.io.tmpdir : /apps/tomcat/temp
java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
java.naming.factory.url.pkgs : org.apache.naming
java.runtime.name : Java(TM) SE Runtime Environment
java.runtime.version : 1.6.0_18-b07
java.specification.name : Java Platform API Specification
java.specification.vendor : Sun Microsystems Inc.
java.specification.version : 1.6
java.util.logging.config.file : /apps/tomcat/conf/logging.properties
java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
java.vendor : Sun Microsystems Inc.
java.vendor.url : http://java.sun.com/
java.vendor.url.bug : http://java.sun.com/cgi-bin/bugreport.cgi
java.version : 1.6.0_18
java.vm.info : mixed mode
java.vm.name : Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name : Java Virtual Machine Specification
java.vm.specification.vendor : Sun Microsystems Inc.
java.vm.specification.version : 1.0
java.vm.vendor : Sun Microsystems Inc.
java.vm.version : 16.0-b13
mail.mime.decodeparameters : true
org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
os.arch : amd64
os.name : Linux
os.version : 2.6.18-274.18.1.0.1.el5
package.access : sun.,
org.apache.catalina.,
org.apache.coyote.,
org.apache.tomcat.,
org.apache.jasper.,
sun.beans.
package.definition : sun.,
java.,
org.apache.coyote.,
org.apache.tomcat.,
org.apache.jasper.
server.loader :
shared.loader :
sun.arch.data.model : 64
sun.boot.library.path : /usr/java/jdk1.6.0_18/jre/lib/amd64
sun.cpu.endian : little
sun.cpu.isalist :
sun.io.unicode.encoding : UnicodeLittle
sun.java.launcher : SUN_STANDARD
sun.jnu.encoding : UTF-8
sun.management.compiler : HotSpot 64-Bit Server Compiler
sun.os.patch.level : unknown
tomcat.util.buf.StringCache.byte.enabled : true
user.country : US
user.dir : /apps/jira-home/log
user.home : /root
user.language : en
user.name : root
user.timezone : US/Pacific
2012-03-14 10:26:13,933 main INFO atlassian.jira.startup.JiraStartupLogger Running JIRA startup checks.
2012-03-14 10:26:13,977 main INFO atlassian.jira.startup.JiraHomeStartupCheck The jira.home directory '/apps/jira-home' is validated and locked for exclusive use by this instance.
2012-03-14 10:26:13,977 main INFO atlassian.jira.startup.JiraStartupLogger JIRA pre-database startup checks completed successfully.
2012-03-14 10:26:14,167 main INFO jira.config.database.SystemTenantDatabaseConfigurationLoader Reading database configuration from /apps/jira-home/dbconfig.xml
TylerA
April 27, 2012
Per Patrick:
Ok, found the source of the issue. On certain linux platforms the random number generation doesn't function correctly. This is a problem as the jdbc driver needs to encrypt the connect string and username/password when transmitting across the wire. If you don't have that the program just hangs and the driver never succeeds in creating the connection. The fix is to add this line to JAVA_OPTS:
-Djava.security.egd=file:/dev../dev/urandom
Then it will work. The issue is described in detail in these blog posts:
http://www.usn-it.de/index.php/2009/02/20/oracle-11g-jdbc-driver-hangs-blocked-by-devrandom-entropy-pool-empty/
https://forums.oracle.com/forums/thread.jspa?messageID=3793101
Norman Abramovitz
March 18, 2012
Are you sure your jira db user has all the permissions it needs to create/insert/update/delete/drop tables/rows?
