JIRA JMWE Groovy - how to check the summary of linked tickets
Sina Esfahani September 8, 2020
I am working with JMWE and trying to write a groovy script where I want to check the summary of the linked tickets and if they do not contain the word 'auto' anywhere in the summary title... it will create a new ticket. I've tried many different combinations and haven't been able to get it to work.
David Fischer
September 8, 2020 edited
Do you want to create one new issue per linked issue that doesn't contain the word "auto" in the summary, or do you want to create a single new issue if none of the linked issues contain "auto" in the summary? Derek's solution above answers the former - for the latter, you'll need to use the "Conditional execution" feature with this script:
!issue.getLinkedIssues().any { it.summary.toLowerCase().contains("auto") }
Also, that will check all linked issues, but not sub-tasks or issues in an Epic. So the code really depends on what you need.
Sina Esfahani September 12, 2020
David, this is exactly what I was looking for! It is the latter. I also have another use case to look for any linked issues where the issue type is documentation. Is this correct? It seems to have worked after testing it....
!issue.getLinkedIssues().any {it.issueType.name == "Documentation"}
David Fischer
That will work. Or if you know the link direction name (as it appears on the issue), you can do:
! issue.getLinkedIssues("has documentation")
which will return true if the issue doesn't have any issue linked to it through the "has documentation" link type direction.
Kris Han
Hi @David Fischer ,
Sorry to bother you,
How should I write the same code but for issue in Epic? I faced the same problem but my linked issues are under issue in Epic. Thank you very much!
David Fischer
Hi @Kris Han ,
it's actually documented in the Issue Methods help tab, but here it is:
issue.stories
Derek Fields _RightStar_
You can use the JMWE Post-Function "Create / Clone Issue(s) Post-function". Check the box "Multiple Issue Creation" In the "Iterator" field, paste:
issue.getLinkedIssues().findAll { ! it.summary.toLowerCase().contains("auto") }
This will return a list of linked issues that do not contain the word "auto". This will then allow you create a new issue for each one that is returned in the iterator.
