JIRA JQL - autocomplete for cascading select lists
Christian Czaia [Decadis AG]
February 19, 2013
Couldn'1 find an answer to this one and the closest I've seen is this one:
https://answers.atlassian.com/questions/37661/autocomplete-for-parameters-in-jql-functions
Could you please confirm, that the autocomplete function is not working with cascading select lists? You'd have to manually search by entering the right values, right?
customfield_11111 in cascadeOption("1st Level","2nd Level")
Cheers Christian
mlassau_atlassian
May 2, 2013
Even if you don't use a function, then cascading select cannot auto-complete as of JIRA 6.0 and below.
eg
customfield_11111 = "2nd Level"
I just found this myself today, and I am in the middle of trying to fix this for v6.1
Melanie Rogers October 9, 2013
What is the JRA issue number?
mlassau_atlassian
October 9, 2013
I actually did the work on an internal JIRA server, but now I copied the issue over so customers can find it.
https://jira.atlassian.com/browse/JRA-35239
(fixed in v6.1)
Adam Jacobson
December 3, 2013
Hi, is this broken again in 6.1.3? It doesn't work for us.
mlassau_atlassian
December 3, 2013
Should clarify: it is currently impossible to do autocomplete on any JQL function including cascadeOption()
What I implemented is for "normal" JQL clauses for cascading select.
So, if you have a cascading CF called "Theme" you can type:
theme = Arch
and JIRA will autocomplete to (say)
theme = Architecture
but it will not be able to autocomplete
theme in cascadeOption(Arch
Was this your problem?
Adam Jacobson
December 3, 2013
Thanks for the fast reponse Mark. We have a cascading CF "Required By" where parent option is a global region (Australia, Italy, etc) and child option is a customer.
In 6.1.3, if I try:
"Required By" = Aus
it does not autocomplete. Similarly at customer level:
"Required By" = "Atlass
(third quote intended) does not autocomplete.
mlassau_atlassian
December 3, 2013
Hmmm ... so I tested on JIRA 6.1.3 and it worked fine ... even with a space in the name.
Just to try to break it, I added a second CF with the same name as the first, and it was only showing me the values from the first field.
Furthermore, when I renamed the first field, it seemed to get even more confused (looks like the autocomplete details are in a stale cache ?).
Does this maybe sound like what happened to you?
If it is caching related, then a JIRA restart may help as a workaround ... ?
(But furst make sure the field names are unique)
This looks like a bug and my guess is that it is not specific to cascading select, but a probelm in auto-complete in general. Needs more testing, and I don't have any more time today.
In the meantime, I have raised https://jira.atlassian.com/browse/JRA-36058 but it would be good to do more investigation.
Please feel free to add more details to above bug report.
Thanks for bringing this to our attention.
MAE O&M
April 22, 2013
https://confluence.atlassian.com/display/JIRA040/Advanced+Searching
I found this to be true. In above documentation it states: "auto-complete is supported for Custom Fields of type picker, group picker, select (except 'Cascading Select'), check-box and radio button fields."
