JIRA/Jenkins integration is not working , when we try to initiate Jenkins build via JIRA status changed.
Its was working fine earlier seems & We don't have changes in Jenkins configurations.
I have the same or similar problem.
I followed the instructions.
Installed versions:
Jira IntegrationVersion5.2.0-23.v990dc373a_0b_f
Jira Software 9.15.0
I get the "online but not accessible" message
Hi @Murugesan
Can you provide some additional context?
Additional context like this makes it possible to help you to debug the issue.
Mark
Installed versions:
The "online but not accessible" error mostly occurs when the authentication configuration is not correct, or the url to Jenkins contains additional path segments after the root url of Jenkins. For example, an incorrect url is `https://jenkins.example.com/api/json/` the correct url is `https://jenkins.example.com/`
If the issue persists, then please reach out to support at getsupport.marvelution.com I'm sure we can get your integration working.
Mark
