JIRA Kanban board columns
Beatrice Cettolin
July 19, 2024
Is it possible to create separate columns for Ready for UAT and PRODUCTION stories in JIRA Kanban board?
Vronik
July 19, 2024
Hi
Of course, in the Kanban board you can create all the columns you need, however, if you want the column to correspond to some state of the workflow, you will also have to create the corresponding state.
Look at this
https://www.atlassian.com/es/agile/tutorials/how-to-do-kanban-with-jira
Regards
Beatrice Cettolin
July 19, 2024
Hi
Thank you for your kind reply.
I would like that both columns correspond to the state DONE so that when an Iteration closes both Ready for UAT and Production stories result DONE. So is it enough that I create a new state DONE from the function Add status and drag it to the new PRODUCTION column and leave the old column named Ready for UAT with state DONE and all stories belonging to both column will result DONE at the end of the Iteration?
Like John Funk likes this
John Funk
July 22, 2024
Yes, but what do you mean by iteration? Are you doing Scrum?
