JIRA LDAP user must be an "administrator for the LDAP engine"
Jeff Dickerson
In the JIRA Administrator's documentation, I noticed the following line:
Ensure that this is an administrator user for the LDAP engine. For
example, in Active Directory the user will need to be a member of the
built-in Administrators group.
Why would the LDAP user need to even have write access, let alone be an Administrator?
I'm using ActiveDirectory, and to get a user with that level of permissions will be difficult.
David Sumlin
This should be clarified in the documentation.
Jobin Kuruvilla [Adaptavist]
February 2, 2015
You do not need this unless you want to write back to AD. Normally, not the recommended approach.
Learn more
