In JIRA, is there anyway to set up labels with hierarchy?
Right now I use "Components" as labels, but it doesn't have hierarchy relationship.
Example:
Tier 1 | Tier 2 |
Science | Computer Science |
Physical | |
Chemicals | |
Philosophy | Mask |
Kong Zi |
Hi
You can create a 2 tier list using the cascading select list custom field.
Hi
I can’t find any documentation to share.
If you know how to create a custom field, Just add a custom field of type Select List (cascading).
it has two levels of entries. The first determines the options at the second level. It’s pretty intuitive to enter the values.
