×Hi all,
I have a problem since I imported a workflow as xml and assigned it to a production project. The workflow itself worked fine on my test system and also looked fine as a diagramm in production.
I noticed in production that in the Workflow Text-Modus 3 Step-Names are not linked with the proper Status and 2 don't have any:
Now, although I changed this missfits, I can't assign the new Workflow (Workflow-Scheme) or the old one to the Project, since I keep getting the same java.lang.NullPointerException:
Cause:
Stack Trace: [hide]
java.lang.NullPointerException at com.atlassian.jira.web.action.admin.workflow.scheme.SelectProjectWorkflowSchemeStep2.getSelectListName(SelectProjectWorkflowSchemeStep2.java:255) at com.atlassian.jira.web.action.admin.workflow.scheme.SelectProjectWorkflowSchemeStep2.addMigrationMappings(SelectProjectWorkflowSchemeStep2.java:181) at com.atlassian.jira.web.action.admin.workflow.scheme.SelectProjectWorkflowSchemeStep2.doExecute(SelectProjectWorkflowSchemeStep2.java:120) at webwork.action.ActionSupport.execute(ActionSupport.java:165) at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:82) at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39) at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31) at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16) at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35) at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:221) at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:150) at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:153) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
Can anyone help please?
Many thanks!
Problem solved:
Two steps had no linked statuses, therefore the nullpointer exception.
I created two temporary statuses (Administration >> Issue Settings >> Statuses
> Add New Status). These new statuses automatically got the id's that were missing, and that the pointer was pointing to. After that the exception was gone and I could replace the scheme.
The Jelly Script didn't work:
Could not run script.
Extra Information: [hide]
on which version of jira you tried?
i tried the same jelly script and get the same error (jira 5.1.8). do you have any information, how i can assign a scheme with jellyscript in my jira version?
regards
try with the jelly script
<JiraJelly xmlns:jira="jelly:com.atlassian.jira.jelly.enterprise.JiraTagLib" xmlns:core="jelly:core" xmlns:log="jelly:log"> <!-- Grab managers. Do it using ComponentAccessor now which gives better compatibility in Jira 5! r --> <core:invokeStatic className="com.atlassian.jira.component.ComponentAccessor" method="getWorkflowSchemeManager" var="workflowSchemeManager"/> <core:invokeStatic className="com.atlassian.jira.component.ComponentAccessor" method="getProjectManager" var="projectManager"/> <!-- Get the project with key "MYPROJECT" using ProjectManager --> <core:invoke on="${projectManager}" method="getProjectObjByKey" var="project"> <core:arg type="java.lang.String" value="MYPROJECT"/> </core:invoke> <log:warn>Project ${project} found</log:warn> <!-- Get the workflow scheme "myScheme" --> <core:invoke on="${workflowSchemeManager}" method="getSchemeObject" var="scheme"> <core:arg type="java.lang.String" value="myScheme"/> </core:invoke> <log:warn>Scheme ${scheme} found</log:warn> <!-- Assign scheme to project --> <core:invoke on="${workflowSchemeManager}" method="addSchemeToProject" > <core:arg value="${project}"/> <core:arg value="${scheme}" /> </core:invoke> </JiraJelly>
check this
