JIRA Post function, created linked issues
kumar jira July 18, 2022
I need some help with the workflow post-function where I wanted to create multiple linked issues in different projects based on a Multi-select custom field values.
Unfortunately, JSU (Create A Linked Issue (JSU)) only support single select field as Target project.
Please let me know if there is any other solution.
Thank you
Fabian Lim
Hi @kumar jira
You may have to use other plugins such as scriptrunner, powerscripts or JMWE which all have scripting capabilities.  JMWE has some linked issues pre-built functions too.
You can also try jira automation, but it will depend exactly on how you are triggering and what you are trying to link.
Regards
