JIRA Project not being displayed in Admin Panel Projects
Jason Gurvitz
October 3, 2012
Getting this error when I try to add an issue under this project name:
"Fix Version/s" field is required and the project "NAME" does not have any versions
I'm trying to modify this project and add a release to it but this project is not being displayed in the Admin panel under projects.
Any idea's as to how to resolve this issue?
Nic Brough -Adaptavist-
October 3, 2012
You need to add one or more versions to the project
To do that, you need to have the project admin permission
If you don't have that permission, then you neeed to grant it to yourself, as a system admin: you'll be able to read the permission scheme for the project, identify the various criteria that grant project admin rights and then modify your access so that it includes one or more of them. If you aren't a system admin, you'll need to talk to the project admins to get it added, or system admins to change the permissions or your rights.
October 3, 2012
Register now
