JIRA Query to find issues where custom field not updated in last 7 days
Leila Nightingale May 30, 2022
Trying to find a query to help me search for any issues where a specific field has not been updated in last 7 days. I've been trying to use the below with little success
issueFunction in issueFieldMatch("Project = JIRA","Custom Field","updated > -7d")
Anyone have any ideas? Thanks
Mohamed Benziane
There is two JQL operator (Changed and WAS) that you can use but only with limited field
https://support.atlassian.com/jira-software-cloud/docs/advanced-search-reference-jql-operators/#Advancedsearchingoperatorsreference-WASWAS
Leila Nightingale June 1, 2022 edited
Changed is exactly what I am after, but unfortunately it is not supported for the field I want to search.
Hemant Daga Official
October 13, 2024
Hi @Leila Nightingale
The above operator is applicable for only limited defined Fields, but not for Custom Fields
 >> This operator can be used with the Assignee, Fix Version, Priority, Reporter, Resolution, and Status fields only.
