×Hi
A GET on rest/api/2/search?jql=filter=123 gets me some info but not the actual results. How do I go about getting the actual results?
Your usage of the REST endpoint is wrong. If you have a filter ID, you use this REST endpoint:
https://docs.atlassian.com/jira/REST/latest/#d2e308
This gives you:
"searchUrl": "http://www.example.com/jira/rest/api/2/search?jql=type%20%3D%20Bug%20and%20resolutino%20is%20empty",
I think what was being asked here, was how would someone execute a filter so that they don't need to manage the query manually. I too would like to know this.
Could you go into a little more detail on this- how can you use the searchUrl from one rest endpoint, to set up another request? Are these all going in the args section of the template function?
I posted a similar follow up question here: https://answers.atlassian.com/questions/41462677
To clarify the solution above, you are using the filter GET API in order to fetch the definition of the filter as a search url (with embedded JQL), then using that url to fetch the actual filter results from the search API. So your choice is to either embed a filter id in your code, or a JQL statement. If the former, you can at least manage the JQL query within JIRA's interface, and have your code fetch the latest definition of that filter before querying the search API for results.
It is quite easy, you first have to request the filter: https://developer.atlassian.com/cloud/jira/platform/rest/#api-api-2-filter-id-get
In the JSON answer the search url is build accordingly in the property "searchUrl".
My question:
I am new to JIRA api. Could some one help me with this. I have url : /rest/api/2/search?jql=project%3DIR&fields=id,summary,status,customfield_10112,priority,customfield_10115&filter=summary%20%3D%20XXX%20AND%20status%20%3D%20YYY&startAt=0&maxResults=3000
Here I am trying to display fields: id,summary,status,customfield_10112,priority,customfield_10115.
I am trying to filter tickets on the basis of: filter=priority%20%3D%20XXX%20AND%20status%20%3D%20YYY.
XXX and YYY are the custom field which I will replace on the basis of dropdown selected.
like
XXX="High or Low..."
YYY="In Progress or Open...."
With this I am not getting filter tickets. I am getting all tickets. Can someone help me with this please.
This gives you:
