Whenever I try to perform a re-index I get the following Error:
java.util.concurrent.ExecutionException: java.lang.NullPointerException
Task completed in 23 seconds with unexpected error.
Started Today 9:49 AM.
Finished Today 9:49 AM.
java.lang.RuntimeException: java.util.concurrent.ExecutionException: java.lang.NullPointerException
at com.atlassian.jira.index.FutureResult.await(FutureResult.java:35)
at com.atlassian.jira.index.CompositeResultBuilder$CompositeResult.await(CompositeResultBuilder.java:82)
at com.atlassian.jira.issue.index.DefaultIndexManager.doIndexIssuesInBatchMode(DefaultIndexManager.java:844)
at com.atlassian.jira.issue.index.DefaultIndexManager.doStopTheWorldReindex(DefaultIndexManager.java:814)
at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexAll(DefaultIndexManager.java:324)
at com.atlassian.jira.issue.index.DefaultIndexManager.reIndexAll(DefaultIndexManager.java:290)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.atlassian.util.profiling.object.ObjectProfiler.profiledInvoke(ObjectProfiler.java:81)
at com.atlassian.jira.config.component.SwitchingInvocationHandler.invoke(SwitchingInvocationHandler.java:28)
at $Proxy124.reIndexAll(Unknown Source)
at com.atlassian.jira.util.index.CompositeIndexLifecycleManager.reIndexAll(CompositeIndexLifecycleManager.java:53)
at com.atlassian.jira.web.action.admin.index.ReIndexAsyncIndexerCommand.doReindex(ReIndexAsyncIndexerCommand.java:28)
at com.atlassian.jira.web.action.admin.index.AbstractAsyncIndexerCommand.call(AbstractAsyncIndexerCommand.java:54)
at com.atlassian.jira.web.action.admin.index.ReIndexAsyncIndexerCommand.call(ReIndexAsyncIndexerCommand.java:16)
at com.atlassian.jira.web.action.admin.index.AbstractAsyncIndexerCommand.call(AbstractAsyncIndexerCommand.java:23)
at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:366)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForTenant(DefaultMultiTenantManager.java:61)
at com.atlassian.multitenant.juc.MultiTenantExecutors$WrappedRunnable.run(MultiTenantExecutors.java:160)
at com.atlassian.jira.task.ForkedThreadExecutor$ForkedRunnableDecorator.run(ForkedThreadExecutor.java:249)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.util.concurrent.ExecutionException: java.lang.NullPointerException
at java.util.concurrent.FutureTask$Sync.innerGet(FutureTask.java:222)
at java.util.concurrent.FutureTask.get(FutureTask.java:83)
at com.atlassian.jira.index.FutureResult.await(FutureResult.java:31)
... 27 more
Caused by: java.lang.NullPointerException
at com.atlassian.jira.issue.changehistory.DefaultChangeHistoryManager.getAllChangeItems(DefaultChangeHistoryManager.java:150)
at com.atlassian.jira.issue.index.DefaultChangeHistoryRetriever.get(DefaultChangeHistoryRetriever.java:53)
at com.atlassian.jira.issue.index.DefaultChangeHistoryRetriever.get(DefaultChangeHistoryRetriever.java:30)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$ChangeHistoryDocumentBuilder.get(DefaultIssueIndexer.java:567)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$IssueLockDocumentCreationStrategy$2.get(DefaultIssueIndexer.java:597)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$IssueLockDocumentCreationStrategy$2.get(DefaultIssueIndexer.java:593)
at com.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:315)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$IssueLockDocumentCreationStrategy.get(DefaultIssueIndexer.java:592)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$IndexIssuesOperation.perform(DefaultIssueIndexer.java:446)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$4$1.get(DefaultIssueIndexer.java:284)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$4$1.get(DefaultIssueIndexer.java:280)
at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:9)
at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:5)
at com.atlassian.jira.index.MultiThreadedIndexingStrategy$1.call(MultiThreadedIndexingStrategy.java:38)
at com.atlassian.jira.index.MultiThreadedIndexingStrategy$1.call(MultiThreadedIndexingStrategy.java:35)
at com.atlassian.jira.util.concurrent.BoundedExecutor$2.call(BoundedExecutor.java:70)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
... 1 more
Hi Tony,
Would you be able to submit this as an official support ticket on support.atlassian.com? That way we will be able to test your instance and data.
Miranda
Discovered in JIRA 5.2.8 as well - Issue only had a summary in the database, all other columns were empty. Removing those two issues from the DB fixed the indexing issue.
