JIRA ReIndex
N
December 8, 2016
I'm using
  • JIRA Core Version 7.2.6 64 Bit on Linux 64 Bit
  • Java 1.8 64 Bit
When I do a reindex of JIRA I got the following error in the log-file:
2016-12-08 14:17:26,757 IssueIndexer:thread-9 WARN anonymous 847x35x1 11wbwdv 10.181.186.236 /secure/SetupImport.jspa [c.a.j.issue.index.DefaultIssueDocumentFactory] Error index
ing issue TOLERANCE-561: Dropping 'customfield_10965'
java.lang.NullPointerException
        at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.movedToSprintAfterStartDate(SprintHistoryEntryFactory.java:223)
        at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.lambda$null$22(SprintHistoryEntryFactory.java:188)
        at java.util.Optional.map(Optional.java:215)
        at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.lambda$removeOtherNonActiveSprints$23(SprintHistoryEntryFactory.java:188)
        at java.util.Collection.removeIf(Collection.java:414)
        at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.removeOtherNonActiveSprints(SprintHistoryEntryFactory.java:185)
        at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.getSprintChangeHistoryForIssue(SprintHistoryEntryFactory.java:154)
        at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.getSprintChangeHistory(SprintHistoryEntryFactory.java:52)
        at com.atlassian.greenhopper.customfield.sprint.SprintCustomFieldIndexer.addDocumentFields(SprintCustomFieldIndexer.java:45)
        at com.atlassian.greenhopper.customfield.sprint.SprintCustomFieldIndexer.addDocumentFieldsSearchable(SprintCustomFieldIndexer.java:30)
        at com.atlassian.jira.issue.index.indexers.impl.AbstractCustomFieldIndexer.addIndex(AbstractCustomFieldIndexer.java:40)
        at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory$Builder.add(DefaultIssueDocumentFactory.java:84)
        at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory$Builder.addAll(DefaultIssueDocumentFactory.java:75)
        at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory.apply(DefaultIssueDocumentFactory.java:50)
        at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory.apply(DefaultIssueDocumentFactory.java:30)
        at com.atlassian.jira.issue.index.DefaultIssueIndexer$DefaultDocumentCreationStrategy.get(DefaultIssueIndexer.java:556)
        at com.atlassian.jira.issue.index.DefaultIssueIndexer$IndexIssuesOperation.perform(DefaultIssueIndexer.java:380)
        at com.atlassian.jira.issue.index.DefaultIssueIndexer$IndexIssuesOperation.perform(DefaultIssueIndexer.java:369)
        at com.atlassian.jira.issue.index.DefaultIssueIndexer.lambda$null$2(DefaultIssueIndexer.java:308)
        at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:7)
        at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:5)
        at com.atlassian.jira.index.MultiThreadedIndexingStrategy$1.call(MultiThreadedIndexingStrategy.java:33)
        at com.atlassian.jira.index.MultiThreadedIndexingStrategy$1.call(MultiThreadedIndexingStrategy.java:31)
        at com.atlassian.jira.util.concurrent.BoundedExecutor$2.call(BoundedExecutor.java:68)
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at java.lang.Thread.run(Thread.java:745)
I do not have any impact on my running system, but I would feel better if I could correct the system, that the error would not occur.
Thanks for any help.
Regards
Norbert
Deleted user February 1, 2017
Hello Norbert,
which database (manufacturer, version)  do you used before the update and which database do you use after the update?
N
February 1, 2017
Hi Peter,
we will upgrade to JIRA 7.3 because we recognized that this version do not cause the error.
Thank you all.
Regards
Norbert
Vasiliy Zverev
December 10, 2016
Hm, it seems that migration from JIRA 6 to JIRA 7 was completed with errors.
Unfortunatelly we do not use Agile and I do know how to migrate it.
Try to find documentation about JIRA Agile migration and follow guids
N
December 9, 2016
Hi Vasiliy,
here is a snapshot from table CUSTOMFIELD:
image2016-12-9 13:31:28.png
Seems for me, that is a custom_field used by JIRA Agile (formerly: Greenhopper).
Any idea?
Thank you
Norbert
Vasiliy Zverev
December 9, 2016
Lets go further.
What is customfield_10965?
What type is it?
Is buid-in type or provided by some plugin?
N
December 8, 2016
Hi Vasiliy,
integrity check do not solve my problem!
Any other hint?
Thank you
Norbert
Vasiliy Zverev
December 8, 2016
Try to execulte integrity check at first. Sometimes it helps.
atlassian, confluence, loom, atlassian intelligence, ai notes, ai-powered meeting notes, atlassian community events, ace, confluence ai, loom ai integration, ai note-taking, atlassian ai features, team '25, atlassian live learning, confluence automation
Unlock AI-powered meeting notes: Join our live learning session! 📹
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!
