JIRA Reindexing takes almost 6 hours
prakashmurugesan April 16, 2018
we are using JIRA 7.5.2 when we try reindexing , everytime it takes 6 hours .
We have around
76 projects
0.4 million issues
30 custom fields.
any suggestion how to fix this?
Mirek
Yes, you can try to tune JIRA settings and see if that helps
https://confluence.atlassian.com/jirakb/tune-number-of-jira-index-threads-826879636.html
sure @Mirek will check and get back to you on this
Victor Seger October 31, 2018
We are facing the same problem but tunning JIRA index threads doesn't help.
Any news about this @prakashmurugesan?
prakashmurugesan November 7, 2018
increasing thread dumps did reduce our time to 50% @Victor Seger
Victor Seger November 8, 2018
How many JIRA index threads did you set?
prakashmurugesan November 11, 2018
@Victor Seger  jira.index.issue.threads = 20 . we did set it to 20
Shirley Tsai
I can't find this jira-config.properties file in $JIRA_HOME or $JIRA_INSTALL.  Searching relevant document, and it seems not to exist in JIRA applications installations and home directory so that it should be created.  Ref: https://confluence.atlassian.com/jirakb/how-to-edit-the-jira-config-properties-file-317194938.html.
I'm creating a new file for jira-config.properties under home directory, and try to re-index again.
