JIRA Resolutions permission config
Jiannan Tang
Hi:
Can JIRA Resolutions support permisson manage.
eg: When resolve an issue, develop only see Fixed, Duplicate, Cannot Reproduce. And other resolutions like 'Won't Fix, Next Version Fix' Only project manage can see.
4 votes
Renjith Pillai
January 16, 2013
Use the workflow properties as described here to exclude some for developers.
https://confluence.atlassian.com/display/JIRA/Workflow+Properties
Define two workflows, one for developers and one for managers protected by a condition based on role/group so that the they see only one which is valid for them.
Jiannan Tang
Thanks I will try it.
Jiannan Tang
Sorry, I think Define two workflows can not solve my question.
Because, the resolve Resolutions(Fixed, Won't Fix, Duplicate, Incomplete ) are not permisson control, they define for global.
I want to control the Resolutions(Fixed, Won't Fix, Duplicate, Incomplete ) permisson.
Can JIRA support this?
Renjith Pillai
January 16, 2013
That is exactly what I said.
  • Define two transitions in the workflow
  • Protect the transitions using conditions so that only developers see theirs and managers see theirs
  • Set the transition properties to include only the required resolutions by setting the field jira.field.resolution.exclude for the developer transition
That's it.
Jiannan Tang
It's perfet for your answer!
Simon Ward
Hi - just a quick question on this.
it looks like it will do what I want, however I can't see how to specify multiple excludes
I have 2 workflows, and a total of 6 valid resolutions across the 2. I want to exclude workflow 2 users from using (and seeing) resolutions 4,5 & 6. I can exclude one of the resolutions by the above method. what about the other 2?
thanks
Renjith Pillai
January 21, 2013
Comma separated resolutions? Like 4,5,6
Simon Ward
Aha! Thanks for that. works a treat!
Register now
