Environment:
sbt version : 1.2.8
jira-rest-java-client-core version : 5.1.0
Steps to reproduce:
1. Create a new sbt project.
2. Add jira-rest-java-client-core as a dependency
https://mvnrepository.com/artifact/com.atlassian.jira/jira-rest-java-client-core/5.1.0
3. Compile the project
Result:
The dependency fails to download with the following error:
[info] Updating ...
[warn] Detected merged artifact: [FAILED ] com.atlassian.sal#sal-api;3.0.7!sal-api.atlassian-plugin: (0ms).
[warn] ==== local: tried
[warn] ==== public: tried
[warn] https://repo1.maven.org/maven2/com/atlassian/sal/sal-api/3.0.7/sal-api-3.0.7.atlassian-plugin
[warn] ==== local-preloaded-ivy: tried
[warn] /Users/sanjeev.pande/.sbt/preloaded/com.atlassian.sal/sal-api/3.0.7/atlassian-plugins/sal-api.atlassian-plugin
[warn] ==== local-preloaded: tried
[warn] file:////Users/sanjeev.pande/.sbt/preloaded/com/atlassian/sal/sal-api/3.0.7/sal-api-3.0.7.atlassian-plugin
[warn] ==== Jira repository: tried
[warn] https://maven.atlassian.com/content/repositories/atlassian-public/com/atlassian/sal/sal-api/3.0.7/sal-api-3.0.7.atlassian-plugin
[warn] ==== Atlassian's Maven Public Repository: tried
[warn] https://maven.atlassian.com/repository/public/com/atlassian/sal/sal-api/3.0.7/sal-api-3.0.7.atlassian-plugin
[warn] ==== Atlassian's Maven Public Repository1: tried
[warn] https://maven.atlassian.com/content/groups/public/com/atlassian/sal/sal-api/3.0.7/sal-api-3.0.7.atlassian-plugin
[warn] ::::::::::::::::::::::::::::::::::::::::::::::
[warn] :: FAILED DOWNLOADS ::
[warn] :: ^ see resolution messages for details ^ ::
[warn] :: com.atlassian.sal#sal-api;3.0.7!sal-api.atlassian-plugin
[error] sbt.librarymanagement.ResolveException: download failed: com.atlassian.sal#sal-api;3.0.7!sal-api.atlassian-plugin
[error] at sbt.internal.librarymanagement.IvyActions$.resolveAndRetrieve(IvyActions.scala:332)
[error] at sbt.internal.librarymanagement.IvyActions$.$anonfun$updateEither$1(IvyActions.scala:208)
[error] at sbt.internal.librarymanagement.IvySbt$Module.$anonfun$withModule$1(Ivy.scala:239)
[error] at sbt.internal.librarymanagement.IvySbt.$anonfun$withIvy$1(Ivy.scala:204)
[error] at sbt.internal.librarymanagement.IvySbt.sbt$internal$librarymanagement$IvySbt$$action$1(Ivy.scala:70)
[error] at sbt.internal.librarymanagement.IvySbt$$anon$3.call(Ivy.scala:77)
[error] at xsbt.boot.Locks$GlobalLock.withChannel$1(Locks.scala:95)
[error] at xsbt.boot.Locks$GlobalLock.xsbt$boot$Locks$GlobalLock$$withChannelRetries$1(Locks.scala:80)
[error] at xsbt.boot.Locks$GlobalLock$$anonfun$withFileLock$1.apply(Locks.scala:99)
[error] at xsbt.boot.Using$.withResource(Using.scala:10)
[error] at xsbt.boot.Using$.apply(Using.scala:9)
[error] at xsbt.boot.Locks$GlobalLock.ignoringDeadlockAvoided(Locks.scala:60)
[error] at xsbt.boot.Locks$GlobalLock.withLock(Locks.scala:50)
[error] at xsbt.boot.Locks$.apply0(Locks.scala:31)
[error] at xsbt.boot.Locks$.apply(Locks.scala:28)
[error] at sbt.internal.librarymanagement.IvySbt.withDefaultLogger(Ivy.scala:77)
[error] at sbt.internal.librarymanagement.IvySbt.withIvy(Ivy.scala:199)
[error] at sbt.internal.librarymanagement.IvySbt.withIvy(Ivy.scala:196)
[error] at sbt.internal.librarymanagement.IvySbt$Module.withModule(Ivy.scala:238)
[error] at sbt.internal.librarymanagement.IvyActions$.updateEither(IvyActions.scala:193)
[error] at sbt.librarymanagement.ivy.IvyDependencyResolution.update(IvyDependencyResolution.scala:20)
[error] at sbt.librarymanagement.DependencyResolution.update(DependencyResolution.scala:56)
[error] at sbt.internal.LibraryManagement$.resolve$1(LibraryManagement.scala:45)
[error] at sbt.internal.LibraryManagement$.$anonfun$cachedUpdate$12(LibraryManagement.scala:93)
[error] at sbt.util.Tracked$.$anonfun$lastOutput$1(Tracked.scala:68)
[error] at sbt.internal.LibraryManagement$.$anonfun$cachedUpdate$19(LibraryManagement.scala:106)
[error] at scala.util.control.Exception$Catch.apply(Exception.scala:224)
[error] at sbt.internal.LibraryManagement$.$anonfun$cachedUpdate$11(LibraryManagement.scala:106)
[error] at sbt.internal.LibraryManagement$.$anonfun$cachedUpdate$11$adapted(LibraryManagement.scala:89)
[error] at sbt.util.Tracked$.$anonfun$inputChanged$1(Tracked.scala:149)
[error] at sbt.internal.LibraryManagement$.cachedUpdate(LibraryManagement.scala:120)
[error] at sbt.Classpaths$.$anonfun$updateTask$5(Defaults.scala:2561)
[error] at scala.Function1.$anonfun$compose$1(Function1.scala:44)
[error] at sbt.internal.util.$tilde$greater.$anonfun$$u2219$1(TypeFunctions.scala:40)
[error] at sbt.std.Transform$$anon$4.work(System.scala:67)
[error] at sbt.Execute.$anonfun$submit$2(Execute.scala:269)
[error] at sbt.internal.util.ErrorHandling$.wideConvert(ErrorHandling.scala:16)
[error] at sbt.Execute.work(Execute.scala:278)
[error] at sbt.Execute.$anonfun$submit$1(Execute.scala:269)
[error] at sbt.ConcurrentRestrictions$$anon$4.$anonfun$submitValid$1(ConcurrentRestrictions.scala:178)
[error] at sbt.CompletionService$$anon$2.call(CompletionService.scala:37)
[error] at java.util.concurrent.FutureTask.run(FutureTask.java:266)
[error] at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
[error] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
[error] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
[error] at java.lang.Thread.run(Thread.java:748)
[error] (update) sbt.librarymanagement.ResolveException: download failed: com.atlassian.sal#sal-api;3.0.7!sal-api.atlassian-plugin
I managed to fix it by adding notTransitive() attribute in the build.sbt
"com.atlassian.jira" % "jira-rest-java-client-core" % "5.1.0" notTransitive(),
and by adding the transitive dependencies manually.
Hello I have the same problem. Could you tell me what do you mean by:
By manually I mean; the jars that were failing to download, I either added them separately with the correct version in the build.sbt or I downloaded them by creating a spring-boot project and kept it in the lib folder or inhouse repository.
Thanks for your reply. How do you find out their full dependencies though, so that you don't miss any jars?
I just added the jars that were listed in the error log. Other dependencies were downloaded by itself.
I still have the same issue for
jira-rest-java-client-core version : 5.2.0
on
sbt version : 1.5.2
In addition
"com.atlassian.platform" % "platform" % "3.1.7"
is listed as a dependency but not available anymore.
I solved the problem adding
resolvers += "Atlassian Public" at "https://maven.atlassian.com/repository/public/"
to the build.sbt
