Sign up Log in
JIRA SSO is not working after upgrading to 8.6.0
dpunna January 9, 2020
Hi Team,
We have upgraded our JIRA to 8.6.0 post which the SSO functionality is not working.
Could you please help us know if there are any compatibility issues for the same.
Kindly help us know the dependencies that are needed for JIRA 8.6.0
Christian Reichert (resolution)
January 10, 2020
Hi!
You, unfortunately, did not mention which plugin you are using - however, my answer should actually apply to all of them.
There is a critical bug in the plugin system from Atlassian on 8.6.0 (8.5 is also affected). Fixed versions are: 8.7.0, 8.6.1, 8.5.3
In a nutshell: in a small number of instances, you will see some plugins fail due to dependency issues. Sometimes reinstalling the plugins a couple of times works, but not always.
For our SAML Single Sign On Plugin we have documented  a workaround.  That should actually work for everyone. But it should also only be used if you can't upgrade to any of the Fix Versions.
Here is a community post with more details: https://community.developer.atlassian.com/t/jira-8-6-is-out/34372/14
And Atlassian's Bug record: https://jira.atlassian.com/browse/JRASERVER-70445
There is also a good Blog Post from fellow vendor Midori describing the Problem: https://midori-global.com/blog/2020/01/06/why-arent-midori-apps-available-for-jira-8.6.0
     Chris
Shradha Kamble
Could you please let me know which JIRA SSO solution are you using? If you have miniOrange SAML(or OAuth) SSO plugin then please raise a request to miniOrange support and the team will help you out with this in no time.
In case if you are using the plugin from any other vendors, then kindly raise a support ticket to them for faster assistance.
Shradha
