JIRA Saved filter using Team field in JQL
Natalia Caban
February 12, 2019 edited
I don't know how to create Jira filter with team fields (not a group).
something like example below which perfectly works for group:
If the filter condition is project = PROJECT AND reporter in membersOf("Group")
I need to be able to see working hours spent for specific projects by one team
Orlando Kelly
try "Team[Team]" =
Toby Jackson January 20, 2021
This is the answer.
As you enter the = JIRA shows a popup of all the teams, and once you select the nicely formatted name it gets replaced by an unguessable ID value.
Presumably this is because the ID won't change, but team names can, so it gets normalised at the point of creating the search interface, but it'd be lovely if this was somehow a little more intuitive for users.
Like • Michael Mack likes this
Luiz Gonzaga dos Santos Filho
March 15, 2021
This didn't work for me :(
I created the team, copied it's id, as made a search with "Team[Team]" = 123id456, didn't work, also tried with "Team[Team] = "My team name", also didn't work. What am I missing?
Like • 2 people like this
Tkachuk Vladyslav
April 30, 2021
The same is for me. Any updates regarding this issue?
Like • Moiz Alam likes this
Kevin Steen
May 12, 2021 edited
@Natalia Caban @Tkachuk Vladyslav & @Luiz Gonzaga dos Santos Filho
This worked for me, once i added "Team[Team] =" and clicked the space, i was presented with a dropdown list of Shared Teams note it was only shared teams that appeared in the list
Like • 3 people like this
Kenyon Barnette
Something that tripped me up until recently is that there are Atlassian Teams and there are Jira Teams. The Atlassian Team is self organizing and helps provide visibility however they will not appear in the JQL Team[TEAM] field. That is the Jira Team that is managed in Plans (as part of Advanced Roadmaps?). Once I had that sorted out I created a Jira Team under Plans which allows my team to show up as an option using JQL.
Where I am currently stuck is searching for issues where the assignee is in that team. When I search on that field I get no results. When I search for tickets assigned to the users in that team, I get the expected results. The Team field is a drop down field and I'm wondering if that needs to be added to the issues and then set?
Like • 7 people like this
Kevin Steen
July 21, 2021 edited
@Kenyon Barnette an issue will need the "Teams" field added to its screen AND the team value will need to be selected within each issue you wish to be able to query.
Fernanda Montes
September 13, 2022
This worked for me, thanks so much!
Joe Sparks
I am in the same boat.  I can create a Team, but I cannot use that team for searching in JQL.  It would be very useful to be able to add a Quick Filter to a sprint board to quickly only show items that belong to that specific team.  Otherwise, the quick filter has to list all members of the team and causes extra overhead when members change teams.
Ayelet Ben-Tzur
Hi @Natalia Caban , did you ever find a solution for this? I'm struggling with the same thing - I want to find assignee from my Team. Otherwise, why would I bother adding people to Team if I can't JQL on that?
Venugopala Naidu
Hi @Natalia Caban,
Please refer below url , you will get the clarification obout JQL
https://confluence.atlassian.com/jirasoftwareserver078/advanced-searching-947191078.html
https://confluence.atlassian.com/jiracore/blog/2015/07/search-jira-like-a-boss-with-jql
And try this below queries:
Project = "XXXX"  AND Reporter in(venu, caban,etc)
or
project = ISSUE AND reporter in membersOf("Support Issue Group")
Venugopal.
Natalia Caban
although I'm not looking for a solution for specific user neither for a group only for teams :)
Venugopala Naidu
Hi @Natalia Caban
The "Team" field is commonly used by different plugins like tempo, portfolio etc.
Thus, first you need to be sure that this field is  NOT a locked field but instead a field created by you with a list of team values. Secondly for a custom field to show values in basic search view you have to make sure that the "context" mapping for that custom field is available for all the issueTypes and Projects selected by the options before. Only then you will see the values.
Venugopal
Teena Monte
August 16, 2021
This worked for me:
"Team[Radio Buttons]" = "replace_this_with-your_team_name"
Joanna Kłak
October 24, 2022
hi, @Teena Monte  could you share whole jql filter?
project="XXX" and Team[embedded]=??? what should I put it??
Bino J
February 4, 2024
Thanks, This worked. The team name got replaced with some UID and it worked
Alexey Matveev
February 12, 2019
From what plugin is the Team field?
If from the Tempo plugin then you could use a JQL like this:
assignee in team("Team Tango")
Nathalie Starr
I suspect what @Natalia Caban is looking to be able to search with is the next-gen new feature called teams - https://confluence.atlassian.com/cloud/start-a-team-976161200.html
Searching using something like membersOf("Support Issue Group") does NOT work for this feature, neither does team("Team Tango")
Neither function works for this next-gen feature.
The question is - how or can we search using these new team groupings?
Like • 14 people like this
Marcelo Gallego
Does anyone have a new update about this really useful and necessary question??
Like • 6 people like this
Tom Lister
Hi
Does anyone know if it is possible to check is a user is a member of an Atlassian Team.
If still not an option I would like to give a customer of definitive answer.
Like • Pratyush Raizada likes this
Pratyush Raizada
June 25, 2025
There is a feature request for this https://jira.atlassian.com/browse/JRACLOUD-81400
Please upvote if you also want this, thanks!
