JIRA Searching with Sub-Tasks
Neil Taylor
Hello All,
Is there a way to do a JIRA filter such that all sub-tasks for a parent ticket are shown after the parent, even if they are not in sequence number order?
Thanks!!!
Bhushan Nagaraj
January 28, 2013
Hey Neil,
As far as I know the closest you can get is by using the JQL Tricks plugin
http://www.j-tricks.com/jql-tricks-plugin.html
Neil Taylor
Thanks! Worked out to be what I needed - helped with some other searching I needed to do as well!
Peter Friberg
I had a similar requirement, and solved it with a Script Runner Calculated Field.
The "Parent Child" scripted field is implemented as below:
Issue myIssue = issue
String issueId = String.valueOf(myIssue.getId())
Issue parentIssue = null
String parentIssueId = ""
if (myIssue.isSubTask()) {
	parentIssue = myIssue.getParentObject()
	parentIssueId = String.valueOf(parentIssue.getId())
	return parentIssueId + "_" + issueId
else {
	return issueId
A reindex may be needed after implementation.
An example value of a regular issue is "167854", and some subtask of this get the values "167854_167585" and "167854_167589"
This search makes the subtasks appear directly after the parent:
project = [Project Key] ORDER BY "Parent Child" ASC
Register today
