Sign up Log in
[JIRA] Separately Import Active Objects XML
Shaakunthala
We have a fairly large JIRA instance (> 1 million issues). A replica of it was created using the XML import method.
Due to an unknown reason none of the active objects data were imported, and we discovered that after doing some develoment work on it.
Is there any way we can separately import only the Active Objects XML file (extracted from backup ZIP), so that we won't have to re-import the entire instance and redo development work?
robert.nadon
May 28, 2020
Wow I am surprised no one answered this.  I assume you have gotten past this and would love to hear the results.    Here is a KB article on it: https://confluence.atlassian.com/cloudkb/how-to-import-only-part-of-a-jira-export-into-jira-cloud-859461966.html
