JIRA Service Desk Agents to restrict access to some issue types
Aravindi Amarasinghe
Hi All,
Is there is a way to restrict access of some Issue types/Workflows for some Agents in the project?
Tansu Akdeniz
July 13, 2018
Hi @Aravindi Amarasinghe,
You can first create an issue level security than set this in Create post-function depending to the issue type.
Ex;
  • Incident -> Set default issue security as ex: "Incident Viewer" includes Group/Role A
  • Question -> Set default issue security as ex: "Question Viewer" includes Group/Role B
Than each group can see only the issues related with their security rights. But keep in mind that portal users shouldn't lose their access after creating it.
Please also check the jira service desk permissions.
Hi @Tansu Akdeniz
Thanks for your answer, with few modifications according to our permission scheme it works for me.
Consulente Atlassian
Hi can you tell me if this behavior can be done for Jira service desk cloud ?
Aaron Geister
October 1, 2020
Go to Issue Security and create a scheme then create the issue security.
