Hi All,
I have an requirement where, I would like to copy a field (basically i have User Picker Custom field) upon transition say from STATUS A to B, Custom field value i.e user name should be assigned as Assignee.
Please help me on this. I would like to achieve this using Post function without any New add on installed.
Is it possible to go with this approach.
Many Thanks,
Akash
Hi, Akash.
You can add a post-function to this transition and use the Copy value from other field post-function from the JIRA Suite Utilities plugin to copy this. ![]()
Matheus
@Matheus Fernandes : I tried using Copy Value from other field but upon transition Assignee is not getting updated. Anything that i am missing. Thanks, Akash
This should work. Where did you put the post-function script? Check the order of the post-functions. Also, try checking the logs for any hints about the issue. Enable JIRA Debug logging if possible.
To complement what Gabrielle said, although silly: make sure the workflow draft was published. :)
@Gabrielle Bautista [ACP-JA] & @Matheus Fernandes Hi All, It worked. THanks a Lot everyone for getting this thing done. Much Appreciated. Many Thanks, Akash
Cheers :)
Hi all, will this post function work to copy value from one field to another within same screen? not from one transition to another or one status to another status. trying to copy value using javascript but not working.
Thanks in advance.
The custom field with values will always be present in an "Issue" and if they are present in the "View Screen". There are "Transition Screens" too and don't mix em up ![]()
Hi Akash,
How u set customfield value to assignee field. we have same issue.
hi,
this solution works on transition which means it goes from state A to B. how can i get assignee when no state changes. in other words, how can i set custom field when user change assignee without changing state in workflow(so no transition fires)?
