JIRA Software- SQL Query for statuses and translation / for custom fields and translation
Sébastien Lucchini September 27, 2018
I want to query  JIRA Software database with SQL query to have :
- workflow statuses and their translation,
- custom fields and their translation.
I found tables :
- issuestatus
- customfield
but, I don't find link to translation tables.
Could you please help me.
Thanks.
Best regards,
Sébastien Lucchini.
Petter Gonçalves
September 27, 2018
 Hello Sébastien,
- For custom field translations, you can check the table entity_translation
- For Statuses translations, you can check the properties tables, as mentioned by @Nic Brough -Adaptavist- in this post:
https://community.atlassian.com/t5/Jira-questions/How-to-translate-results-and-status-in-jira-database/qaq-p/171207
Sébastien Lucchini October 1, 2018
Hello Petterson,
Thank you.
I don't find entity_translation table but I find query :
select CF.cfname, CF.description, PE.entity_name, PE.PROPERTY_KEY, PS.PROPERTYVALUE
from customfield CF, propertyentry PE, propertystring PS
where CF.id = PE.entity_id
and PE.id = PS.id
and PE.entity_name in ('CustomField')
order by 1, PE.PROPERTY_KEY
I'm looking for translation for statuses.
Best regards,
Sébastien Lucchini
