JIRA Startup Failed on migration to jira 7
Esty Heller
September 7, 2016
Help!
I just tried migrating from JIRA 6.3 to JIRA 7.2
Everything LOOKED like it was going ok, until after about 10 minutes of the starting up animation in the browser, it ends with this message
JIRA Startup Failed
The following plugins are required by JIRA, but have not been started:
  • JIRA Projects Plugin (com.atlassian.jira.jira-projects-plugin)
  • Atlassian Navigation Links Plugin (com.atlassian.plugins.atlassian-nav-links-plugin)
  • Atlassian JIRA - Plugins - Project Config Plugin (com.atlassian.jira.jira-project-config-plugin)
  • Applinks - Plugin - Core (com.atlassian.applinks.applinks-plugin)
  • Atlassian OAuth Service Provider Plugin (com.atlassian.oauth.serviceprovider)
  • Embedded Gadgets Plugin (com.atlassian.gadgets.embedded)
  • Gadget Directory Plugin (com.atlassian.gadgets.directory)
  • Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
  • Atlassian JIRA - Plugins - Global Issue Navigator (com.atlassian.jira.jira-issue-nav-plugin)
  • Atlassian JIRA - Plugins - Quick Edit Plugin (com.atlassian.jira.jira-quick-edit-plugin)
  • Atlassian REST - Module Types (com.atlassian.plugins.rest.atlassian-rest-module)
  • Atlassian JIRA - Plugins - REST Plugin (com.atlassian.jira.rest)
  • Opensocial Plugin (com.atlassian.gadgets.opensocial)
  • Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard)
I ran stop-jira.sh, which killed tomcat. Then I ran on the db
update pluginstate set pluginenabled='true';
based on the first answer here. And then I restarted jira. Another loooong promising wait, but ended with the same exact error.
What can I do from here?
Thanks.
rmorstein March 9, 2017
I had a heck of a time upgrading. I ultimately copied over plugins from my dev environment. this allowed the system to boot. I then had multiple values set for Rank (Obsolete):. I removed the duplicated entries from the database. It was a full Saturday......
Maria Thoma March 8, 2017
i also run
and now i'm getting the same error (as the screnshot) above. Did anyone of you managed to overcome this problem?
Karen Mixon February 21, 2017
Do you have the plugin:  plugin-license-storage-plugin-2.2.4.jar ?
That caused the problem for us.  Try removing prior to upgrade.
rmorstein February 21, 2017
looked and its not present, I am in dev so I have time to rebuild and try again & again ......
me to friends
Karen Mixon January 5, 2017
Same here.
Mathiyalagan
December 15, 2016
I too endup with same error after upgrading JIRA from 6.4.4 to 7.2.0
Ismo Ismo
November 7, 2016
I have exactly the same issue
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
