JIRA Startup Failed: plugins not started
Stefan Schablowski December 18, 2012
I have installed the latest version of JIRA on Debian 6.0.6 i386 and initially, it seemed to work ok. After a number of reboots, I get the error message
You cannot access JIRA at present. Look at the table below to identify the reasons
Description
The following plugins are required by JIRA, but have not been started:
  • Gadget Dashboard Plugin (com.atlassian.gadgets.dashboard)
  • Gadget Directory Plugin (com.atlassian.gadgets.directory)
  • Atlassian JIRA - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
I would usually just check the logs for what went wrong, but Atlassian logs are so verbose that they give me a really hard time finding anything relevant. Some advanced grepping has revealed these lines though that seem related to the problem at hand:
2012-12-19 11:21:00,157 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.gadgets.dashboard], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory]), Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder)] (from bean [&renderedGadgetUriBuilder]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.dashboard' has timed out
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105)
at java.util.TimerThread.mainLoop(Unknown Source)
at java.util.TimerThread.run(Unknown Source)
2012-12-19 11:21:00,169 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)
2012-12-19 11:21:00,169 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2012-12-19 11:21:00,169 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&renderedGadgetUriBuilder' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.view.RenderedGadgetUriBuilder)
2012-12-19 11:21:00,170 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.dashboard' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
So if I understand this correctly, some java dependency is unsatisfied and some plugin can not be started.
That dependency must have been there before as JIRA did work. How can it just disappear ? I have certainly not touched anything.
Does anyone have some advice for me how to find the cause of this problem and solve it ?
Update:
I can get JIRA to work again by shutting it down, deleting some folder using
rm -r /opt/atlassian/jira/work/*
and restarting JIRA.
The problem is that this issue occurs *every single time* the server JIRA runs on is rebooted.
4 votes
Stefan Schablowski January 14, 2013
The root cause of this problem seems to be that JIRA simply does not shut down cleanly whenever the server it runs on is shut down. Most users probably do not notice that as their JIRA machine simply is always on. For the moment, I simply delete the work folder manually before trying to start JIRA, in the longer run, I might hack the JIRA startup scripts to do this automatically.
Michael Brinson June 11, 2014
I have the same experience. Bummer.
I didn't have this problem in previous versions of Jira.
David O'Neill
December 4, 2014
My test Jira server was bounced, started JIRA after reboot deleted the contents of home directory like Stefan indicated and worked so thanks for the post.
Naren
December 18, 2012
Please check with the following aspects w.r.t your JIRA installation -
  1. Antivirus scanning JIRA directories (Home and installation directories) (Stop the anti-virus / firewall while JIRA is getting installed)
  2. Invalid Java version - 1.7 (install JDK 1.6)
  3. Timout during plugin installation (due to memory resources issue)
  4. Try deleting the .osgi-plugins, bundled-plugins directory located under <JIRA_HOME>/plugins/ in order to re-extract the plugins on jira startup.
If the problem still persists, follow the steps given here
Some more useful links -
Increasing JIRA plugin Timeout
Gadgets Plugin Not Available
Jira Locked
Hope it helps!
Theinvisibleman
December 18, 2012
It seems that you might be hitting a known issue. Please check out and try the resolution steps mentioned here : https://confluence.atlassian.com/display/JIRAKB/JIRA+does+not+Start+Due+to+Disabled+Bundled+Plugin
Register today
