Hello everyon,
I am encountring following issue when i start JIRA local setup instance. I used "atlas-run-standalone --product jira -e" command. I am proxy setting in setting.xml but still not able to starting development instnace.
please advise.
[INFO] [cargo:start]
[INFO] [2.ContainerStartMojo] Resolved container artifact org.codehaus.cargo:cargo-core-container-tomcat:jar:1.2.3 for container tomcat6x
[INFO] [stalledLocalDeployer] Deploying [C:\workspace\atlastutorial\amps-standalone\target\jira\jira.war] to [C:\workspace\atlastutorial\amps-standalone\target\container\tomcat6x\cargo-jira-home/webapps]...
[INFO] [talledLocalContainer] Tomcat 6.x starting...
[INFO] [yer.DeployerWatchdog] Deployable [http://localhost:2990/cargocpc/index.html] failed to finish deploying within the timeout period [600000]. The Deployable state is thus unknown.
[INFO] ------------------------------------------------------------------------
[ERROR] BUILD ERROR
[INFO] Unable to execute mojo
[INFO] Trace
org.apache.maven.lifecycle.LifecycleExecutionException: Unable to execute mojo
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:703)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeStandaloneGoal(DefaultLifecycleExecutor.java:553)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:523)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:371)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:268)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:181)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:356)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:137)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:356)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.MojoExecutionException: Unable to execute mojo
at com.atlassian.maven.plugins.amps.RunStandaloneMojo.doExecute(RunStandaloneMojo.java:97)
at com.atlassian.maven.plugins.amps.AbstractProductHandlerMojo.execute(AbstractProductHandlerMojo.java:643)
at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:483)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:678)
... 16 more
at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojoImpl(MojoExecutor.java:128)
at org.twdata.maven.mojoexecutor.MojoExecutor$ExecutionEnvironmentM2.executeMojo(MojoExecutor.java:466)
at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojo(MojoExecutor.java:80)
at com.atlassian.maven.plugins.amps.MavenGoals.executeAmpsRecursively(MavenGoals.java:117)
at com.atlassian.maven.plugins.amps.RunStandaloneMojo.doExecute(RunStandaloneMojo.java:93)
... 19 more
at com.atlassian.maven.plugins.amps.MavenGoals.startWebapp(MavenGoals.java:853)
at com.atlassian.maven.plugins.amps.product.AbstractWebappProductHandler.startApplication(AbstractWebappProductHandler.java:71)
at com.atlassian.maven.plugins.amps.product.AbstractProductHandler.start(AbstractProductHandler.java:64)
at com.atlassian.maven.plugins.amps.RunMojo.startProducts(RunMojo.java:124)
at com.atlassian.maven.plugins.amps.RunMojo.doExecute(RunMojo.java:87)
at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojoImpl(MojoExecutor.java:126)
... 23 more
Caused by: org.codehaus.cargo.container.ContainerException: Failed to start the Tomcat 6.x container. Check the [C:\workspace\atlastutorial\amps-standalone\target/jira-LATEST.log] file containing the container logs for more d
etails.
at org.codehaus.cargo.container.spi.AbstractLocalContainer.start(AbstractLocalContainer.java:179)
at org.codehaus.cargo.maven2.AbstractContainerStartMojo.doExecute(AbstractContainerStartMojo.java:61)
at org.codehaus.cargo.maven2.ContainerStartMojo.doExecute(ContainerStartMojo.java:52)
at org.codehaus.cargo.maven2.AbstractCargoMojo.execute(AbstractCargoMojo.java:431)
... 33 more
Caused by: org.codehaus.cargo.container.ContainerException: Deployable [http://localhost:2990/cargocpc/index.html] failed to finish deploying within the timeout period [600000]. The Deployable state is thus unknown.
at org.codehaus.cargo.container.spi.deployer.DeployerWatchdog.watch(DeployerWatchdog.java:111)
at org.codehaus.cargo.container.spi.AbstractLocalContainer.waitForCompletion(AbstractLocalContainer.java:254)
at org.codehaus.cargo.container.tomcat.internal.AbstractCatalinaInstalledLocalContainer.waitForCompletion(AbstractCatalinaInstalledLocalContainer.java:212)
at org.codehaus.cargo.container.spi.AbstractLocalContainer.start(AbstractLocalContainer.java:173)
... 38 more
[INFO] Total time: 16 minutes 34 seconds
[INFO] Finished at: Thu May 30 14:40:25 PDT 2013
[INFO] Final Memory: 54M/326M
C:\workspace\atlastutorial>
You are most likely facing same issue reported here: https://answers.atlassian.com/questions/172456/unable-to-run-the-atlas-standalone-product-jira-command Try that suggestion and see if it helps
