JIRA Timesheets - Inconsistency in REST API user info returned
Nimalka Lucas May 28, 2015
Hi
When using the rest api to get the worklog information, certain users indicated as active: false and less information displayed on them. Both users are active on the cloud and have been created in the same way.
Below example shows 2 work logs with 2 users which has this mismatch, but couldn't find any difference the way they have setup
Worklog with incorrect user information format
image2015-5-28 17:37:12.png
Work log with correct user information format
image2015-5-28 17:37:20.png
Nimalka
Andriy Zhdanov
May 31, 2015
Hi Nimalka,
I have also noticed this problem and reported it to Atlassian, please see https://ecosystem.atlassian.net/browse/ACJIRA-300and comment or vote on it.
Thank you.
