JIRA Unread Comment Indicator
Duncan DAVIES March 29, 2012
Hi
I have been asked to implement some sort of indicator that there are new/unread comments on an issue. I realise JIRA doesnt do this natively, but was wondering if anyone had any ideas/done something to reproduce this sort of functionality.
I was initially hoping to just increment a field when a new comment was added, and have a workflow transition to set the field to 0, but am not 100% sure how to complete the first part
Aspect Infra Team
March 29, 2012
oo... so you want an unread comment indicator not as a flag for users that they have comments unread on issue but as a flag do or not assignee reads all of changes in issue?
at least as i see you can remove comment from menu and add another fake transition with a comment screen and this 'counter' field modification
I was planning on just the Assignee to be able to reset the count to 0 - as they are the main person the count is there for
Aspect Infra Team
March 29, 2012
you should bear in mind that you need per-user unread indicator - so one counter is not enough
imho you need a flag per issue per user but this can be a pretty good load for big jira instances
