I just tried to upgrade JIRA 6.2.6 to 6.3 and now I am stuck with a broken database and nothing runs anymore. There a no additional plugins installed, it was just a plain JIRA 6.2.6. Is there a way to fix that - except reinstallation of a clean 6.2.6 and restoring a backup?
An error occurred performing JIRA upgrade
Exception thrown during upgrade: Ungültiger Objektname 'jiraeventtype'.
java.sql.SQLException: Ungültiger Objektname 'jiraeventtype'.
at net.sourceforge.jtds.jdbc.SQLDiagnostic.addDiagnostic(SQLDiagnostic.java:368)
at net.sourceforge.jtds.jdbc.TdsCore.tdsErrorToken(TdsCore.java:2820)
at net.sourceforge.jtds.jdbc.TdsCore.nextToken(TdsCore.java:2258)
at net.sourceforge.jtds.jdbc.TdsCore.getMoreResults(TdsCore.java:632)
at net.sourceforge.jtds.jdbc.JtdsStatement.executeSQLQuery(JtdsStatement.java:477)
at net.sourceforge.jtds.jdbc.JtdsPreparedStatement.executeQuery(JtdsPreparedStatement.java:778)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
at com.atlassian.jira.upgrade.tasks.util.Sequences.update(Sequences.java:36)
at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build6320.doUpgrade(UpgradeTask_Build6320.java:41)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeTaskSuccess(UpgradeManagerImpl.java:691)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.runUpgradeTasks(UpgradeManagerImpl.java:540)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgrade(UpgradeManagerImpl.java:469)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeIfNeeded(UpgradeManagerImpl.java:411)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeIfNeededAndAllowed(UpgradeManagerImpl.java:346)
at com.atlassian.jira.upgrade.UpgradeLauncher.checkIfUpgradeNeeded(UpgradeLauncher.java:106)
at com.atlassian.jira.upgrade.UpgradeLauncher.start(UpgradeLauncher.java:54)
at com.atlassian.jira.startup.ActiveServicesLauncher.start(ActiveServicesLauncher.java:42)
at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:133)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:324)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:214)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:115)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:31)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:78)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:34)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:73)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:70)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4939)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5434)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1559)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1549)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
I think you should open a support case at https://support.atlassian.comfor this - you're missing a column that should be there, they should be able to get you back on track.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
