Hello!
I'm having a problem where the send email post function is no longer sending emails, the post function testing resolved correctly, and it used to work in the past, just suddenly stopped working.
Steps my team and I have taken to debug:
None of these steps have yielded results. The post function lives in the create transition of a specific issue type, the issue gets created normally, but no email is sent.
Is there a place I can check to see why the emails are not getting sent when it's going out to that DL? I can send and receive emails to the DL normally.
Thank you
Pierre Ibrahim
Closing the loop on this, the issue was on our side with how the DL was created
Hello @Pierre Ibrahim,
I am part of the support team of Decadis and I would like to assist you with this problem.
Would you mind creating a request in our support portal so that we can have a closer look at it?
Thank you for your interest in our app.
Best regards,
Vicente
Hi @Pierre Ibrahim , thanks for your question.
Have you checked the documentation for the app, https://apps.decadis.net/display/JWTSDC/Send+email . Sometimes you can find other troubleshooting tips there.
If not, I would encourage you to reach out to the vendor, who are normally the best placed to give this kind of advice - https://marketplace.atlassian.com/apps/29496/jira-workflow-toolbox?hosting=datacenter&tab=support .
I hope this helps you. Good luck!
