I'm using the JIRA default workflow. I'm trying to configure the workflow in such a way that a user cannot move a story to the "in progress" state unless the "story points" field contains a value.
I've explored the built-in validator options with no luck...
How can I configure the workflow transition to acomplish this? Any help or direction is much appreaciated!
The JIRA Suite Utilities plugin has a "Fields required, mandatory, during transition" condition that you can use to achieve this. :)
Hi Julian,
I'm glad to hear that it helped. You may mark this question as answered, so that this will help others making it more visible.
Cheers
