JIRA Workflow error
Shashank Agrawal August 14, 2019
HI,
Whenever i click workflows in jira, it throws an error. Please let me know how can i fix it.
Below is the error
2019-08-14 14:19:36,703 http-nio-8080-exec-9 ERROR shashank.agrawal 859x74x1 1e3kwta 0:0:0:0:0:0:0:1 /rest/projectconfig/latest/workflowscheme/BD [c.a.p.r.c.error.jersey.ThrowableExceptionMapper] Uncaught exception thrown by REST service: java.lang.RuntimeException: com.opensymphony.workflow.FactoryException: Error converting XML to workflow descriptor.: root cause: An invalid XML character (Unicode: 0x0) was found in the value of attribute "name" and element is "action". (line:37 col:37)
com.atlassian.cache.CacheException: java.lang.RuntimeException: com.opensymphony.workflow.FactoryException: Error converting XML to workflow descriptor.: root cause: An invalid XML character (Unicode: 0x0) was found in the value of attribute "name" and element is "action". (line:37 col:37)
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:211)
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:162)
at com.atlassian.jira.workflow.CachingWorkflowDescriptorStore.getWorkflow(CachingWorkflowDescriptorStore.java:64)
at com.atlassian.jira.workflow.JiraWorkflowFactory.getWorkflow(JiraWorkflowFactory.java:33)
at com.opensymphony.workflow.config.DefaultConfiguration.getWorkflow(DefaultConfiguration.java:89)
at com.atlassian.jira.workflow.OSWorkflowManager.getWorkflow(OSWorkflowManager.java:189)
at com.atlassian.jira.workflow.OSWorkflowManager.getWorkflows(OSWorkflowManager.java:121)
... 3 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy481.getWorkflows(Unknown Source)
... 3 filtered
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:133)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:121)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
at com.sun.proxy.$Proxy1899.getWorkflows(Unknown Source)
at com.atlassian.jira.projectconfig.rest.WorkflowSchemeRestHelper$ResponseDataBuilder.build(WorkflowSchemeRestHelper.java:171)
at com.atlassian.jira.projectconfig.rest.project.WorkflowSchemeResource.generateSchemeData(WorkflowSchemeResource.java:153)
at com.atlassian.jira.projectconfig.rest.project.WorkflowSchemeResource.getWorkflowSchemeInfo(WorkflowSchemeResource.java:78)
... 3 filtered
... 19 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:154)
... 1 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:68)
... 32 filtered
at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(ExternalCustomerLockoutFilter.java:56)
... 13 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 53 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 16 filtered
at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:37)
... 19 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 5 filtered
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(CustomerContextSettingFilter.java:181)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.rteInvoke(ReentrantThreadLocalBasedCodeContext.java:137)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.runOutOfContext(ReentrantThreadLocalBasedCodeContext.java:90)
at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.runOutOfCustomerContext(CustomerContextServiceImpl.java:47)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(CustomerContextSettingFilter.java:174)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(CustomerContextSettingFilter.java:130)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(CustomerContextSettingFilter.java:121)
... 4 filtered
at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:32)
... 8 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 26 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 24 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Nic Brough -Adaptavist-
August 14, 2019
I think you have a damaged workflow in the database.
When you say "I click workflows" - what do you mean?  Admin?  Issue view?  Project admin?   I say because you probably need to work out which workflow it is and delete it, and there's ways we need to explore to find it first!
