JIRA-XRAY - REST API - error
Ajay Taneja
January 20, 2023 edited
deleted
2 accepted
Stefan Salzl
Asha Goyal
January 22, 2023
The error message you are receiving, {"error":"components: components"}, suggests that the Jira API is expecting the imported test results to include information about the components that the tests are associated with, but the information is not being provided in the request.
To fix this, you will need to add a parameter to your curl command that specifies the component(s) associated with the test results. The parameter should be added to the end of the URL in your curl command and should be in the format of "&components=component1,component2,component3" where "component1, component2, component3" is a list of the component names.
It is also possible that the issue is coming from the permissions you have on the project, check if you have the right permission to import test results.
Another thing is to check the xml file you are uploading. Make sure that it is a valid junit report file.
It is also recommended to check the Jira API documentation to confirm the format of the data that is expected in the request and to see if there are any other parameters or settings that may be required.
Ajay Taneja
January 25, 2023 edited
Hi @Asha
That didn't work:
I got the same error
Ajay Taneja
I have the permissions to import results and the file is I'm sure correct
