JIRA addon: Agile cards: 'Uncaught TypeError' when generating PDF
Lucas Molenaar
September 18, 2012
When using the addon "Agile Cards" I encounter the following problem when creating a cards PDF
Steps:
  1. Agile --> Scrum board: PLAN
  2. Press the PRINTER button (Agile Cards (PDF) - Print sprint issues)
This does not occur on a different project with a kanban view.
Anyone any idea what the cause might be?
  • JIRA 5.1.4
  • Agile Cards 2.1.1
Thiago Ribeiro
September 18, 2012
Lucas,
You are running Jira 5.1.4 which is not compatible with Agile Cards from Spartez.
Have you tried to contact Spartez (mail@spartez.com)?
I would suggest you to get their support on this case. Also how did you get the version 2.1.1?
Lucas Molenaar
September 19, 2012
Thanks Thiago, I installed the plugin via the marketplace I believe, after I upgraded JIRA. Will contact Spartez support
Read the story
