JIRA and Microsoft Active Directory
Arnold Chang June 5, 2013
I'm using Microsoft Active Directory for user and group management in my organization.
As a result, we will use it for authentication to JIRA.
One of my doubts is whether JIRA User will become deavtivated automatically in sync with the AD account which has been deactivated 2 hrs ago. Normally AD and JIRA will be sync up every 60 minutes in my environment.
Arnold
Alex Perez
June 5, 2013
Hi Arnold,
As Bhushan stated before, disabling a user in AD doesn't disable it in Jira. But it prevents that the user can login in jira.
Additionally you must remove the user from the jira-users group for both release his licence and revoke his login-permission.
HTH
Bhushan Nagaraj
June 5, 2013
Hi Arnold,
Disabling a user in active directory does not disable the user in JIRA.
There is an improvement request here
https://jira.atlassian.com/browse/JRA-24937
And there are lots of questions about it on Answers as well. Read
https://answers.atlassian.com/questions/83692/how-to-auto-deactivate-jira-users-when-using-ldap-integration
https://answers.atlassian.com/questions/139606/what-happens-with-the-users-that-are-removed-from-ldap-when-you-use-crowd-ldap-connector
Cheers
Bhushan
Register now
