JIRA and SQL Server
Robert Egan
March 30, 2022 edited
Apologies in advance for the vagueness. Has anyone setup JIRA to use a SQL Server database with Windows Authentication? If so, can you send me the <url> from your dbconfig.xml? You can blank out the serverName attribute, because I am reasonably sure that's not our issue.
Are there any special files I need to add to either the OS, the JVM or the Jira installation? What I have been able to find on the internet has not worked.
Anything needed on the Database side?
SQL Server 2017 Building the connection string
SQL Server 2017 JDBC Connection properties
