In JIRA 6.4 (I think) Atlassian changed the list of Default list of JIRA Priorities from Blocker, Critical, Major, Minor, Trivial etc. to Highest, Higher, Medium, Lower, Lowest. Our plan is to change to the new values, since our values have been tempered with in a strange way.
I have tried to find some writing around the rational behind this change, since I consider Atlassian to deliver and change their Products, based on Best Practices.
My reason for asking is that in my Company, there are som User Groups that suggests other values and I want to bring the right ammunition to the table.
and now they have changed it to (1) high, (2) Normal and (3) low.
The change was made in JIRA 6.4, however nothing is mentioned in the Release Notes.
Your best bet would be to contact Atlassian Support and ask them for an explanation.
Yes they have. Please look into:
Doc for latest version: https://confluence.atlassian.com/display/JIRA/What+is+an+Issue#WhatisanIssue-Priority
Doc for 6.3: https://confluence.atlassian.com/display/JIRA063/What+is+an+Issue
Atlassian didn't change the priority names. Are you sure one of your admins didn't change it?
