JIRA finding users for a given directory
Robert G. Nadon
November 10, 2015
Hi all,
I have what I thought would be a very easy operation, but I am a little stuck.  We have 2 users directories:
  1. JIRA Internal
  2. LDAP
The JIRA internal should be just used for my administration and the like, but I just stumbled across a user who was internal.  So I need to find all users who are internal so I can get them to start using ldap ID instead.  I go to user and there is no directory filter.  Also I cannot click on the column title to sort by Directory.
All I need is to find all users who are part of the JIRA internal directory.  Is there a way to do this?
(I did find this https://confluence.atlassian.com/jira/migrating-users-between-user-directories-426116517.html on migrating users but I do not have the option Migrate users from one directory to another under User Directories)
Thanks in advance!
Robert
2 accepted
7 votes
Jordan Packer
Only way I know of is to query the database directly.... something like this ought to do the trick:
SELECT * FROM cwd_user
WHERE directory_id = 1
Robert G. Nadon
November 10, 2015
Really? interacting directly with the database? Wow. I think I will submit that as a feature request as it seems very easy and I could really see the usage. Thanks! Robert
Like Espen Sandall likes this
Robert G. Nadon
November 10, 2015
BTW that worked great. Thanks again.
Martin Cleaver
April 3, 2016
Robert: did you find or submit a feature request for this?
Robert G. Nadon
April 3, 2016
No, I used Jordan's database query and that gave me what I needed.
Robert G. Nadon
November 16, 2016
Using the JIRA internal database is very dangerous.  I strongly recommend using a separate mysql database.   However here is how: https://confluence.atlassian.com/jirakb/running-sql-commands-in-a-hsql-database-685900390.html
Kristin Bitler May 18, 2017
Something via the UI would be nice.
Salim Morgan
July 2, 2018
I found a macro on-line and modified it a little. It gets the KEY for the user directory. I haven't been able to get the name, but no biggie. Look at the user to see the actual user directory and learn what the two numbers mean. Here's the template:
## Macro title: Last Login
## Macro has a body: N
## Body processing: Selected body processing option
## Output: Selected output option
## Developed by: Andrew Frayling
## Modified by: Michael Seager [Atlassian Support]
## Mofified by: Salim Morgan (STCS, Riyadh)
## Date created: 11/02/2012
## Installed by: <your name>
## Macro to display the last login date of users who have access to the current space
## @noparams
#set($containerManagerClass = $content.class.forName('com.atlassian.spring.container.ContainerManager'))
#set($getInstanceMethod = $containerManagerClass.getDeclaredMethod('getInstance',null))
#set($containerManager = $getInstanceMethod.invoke(null,null))
#set($containerContext = $containerManager.containerContext)
#set($loginManager = $containerContext.getComponent('loginManager'))
#set($users = $userAccessor.getUsers())
<table class="confluenceTable">
<tr>
<th class="confluenceTh">Count</th>
<th class="confluenceTh">User</th>
<th class="confluenceTh">Login Name</th>
<th class="confluenceTh">Last Successful Login</th>
<th class="confluenceTh">Directory</th>
</tr>
#set($count = 0)
#foreach($user in $users)
## list the last login date of users who can view the current space
#if ($permissionHelper.canView($user, $space))
#set($count = $count + 1)
<tr>
<td class="confluenceTd">$count</td>
<td class="confluenceTd">#usernameLink($user.name)</td>
<td class="confluenceTd">$user.name</td>
<td class="confluenceTd">$action.dateFormatter.formatDateTime($loginManager.getLoginInfo($user.name).lastSuccessfulLoginDate)</td>
<td class="confluenceTd">$user.directoryId</td>
#end
#end
</table>
Grigory Salnikov
November 8, 2018
It worked for our Confluence server.
7 votes
Joachim Brechtel
You can also look them up using scriptrunner script console
def userManager = ComponentAccessor.userManager
def allUsers = userManager.allUsers
List<ApplicationUser> results = []
allUsers.each {
if (it.directoryId == 1L) {
results.add(it)
def prettyPrint = ""
results.each {
prettyPrint += it.displayName + "(" + it.name + ") - Active: " + it.active + "<br>"
prettyPrint
Tim_C
January 9, 2020
Hi @Joachim Brechtel
I'm trying to adapt your scriptrunner script above to additionally include "email address" in the prettyPrint results of the Jira user directory. It's already working fine and showing displayname, username and active flag. Any advice would be much appreciated.
Tim
Joachim Brechtel
January 9, 2020 edited
Hi @Tim_C ,
you can use
prettyPrint += it.displayName + "(" + it.name + ") - Active: " + it.active + ", Email: " + it.emailAddress + "<br>"
The result contains a list of com.atlassian.jira.user.ApplicationUser. You can find the API reference here: https://docs.atlassian.com/software/jira/docs/api/7.1.0/com/atlassian/jira/user/ApplicationUser.html
Best, Joachim
Tim_C
January 10, 2020
Hi @Joachim Brechtel - perfect, thanks for your very quick response.
Marc Jason Mutuc
May 28, 2020
@Joachim Brechtel , thank you! I took you script to use for mine as well. Here is my final script.
allUsers.each {
if (it.directoryId == 1L && it.emailAddress ==~ /(?s).*kambi.*/ && it.active == true) {
results.add(it)
results.each {
prettyPrint += it.displayName + "(" + it.name + ") - Email: " + it.emailAddress + "<br>"
prettyPrint
 Just one question, this line
Is showing a warning saying not to pull allusers if not needed. What should be the fix?
Joachim Brechtel
Hi @marco@Marc Jason Mutuc ,
the warning just indicates that this method may cause performance impact (it is also deprecated, so it might not work in future).
The solution would be to take com.atlassian.jira.bc.user.search.UserSearchService and build a query which includes all users. But as long as Atlassian keeps the method, I would continue to use it.
Avinash Singh
Can this functionality be added to the UI so that was can easily search users from a particular user directory (Internal, LDAP, Crowd)
I guess this is a no and we can't vote on it, since no one ever answered. It would make my life far easier to manage the 2000+ users we have.
Richard Burstiner
Submitted JRASERVER-65844 to add a filter on the "user management" screen.
Florian Schmidt June 6, 2017
Is there an update on this issue or do we still have to do this with SQL?
Get Certified! ✍️
