I'm facing a problem after testing upgrade from Jira 7.1 to 7.9. After importing the XML export in Jira the instance is getting stuck with the same symptoms as:
https://confluence.atlassian.com/jirakb/jira-hangs-at-the-startup-page-937890815.html
The last lines in catalina.out / atlassian-jira.log are:
2018-06-11 17:17:55,403 JIRA-Bootstrap INFO [c.t.upgrade.tempo7.UpgradeTask29MigrateWorklogAttributes] Total migrated attribute: 0 in 44 ms
2018-06-11 17:17:57,849 Modification Check:thread-1 INFO [c.a.jira.startup.JiraStartupLogger]
___ Modifications ___________________________
Modified Files : jira-application.properties
Removed Files : None
2018-06-11 17:18:55,730 hipchat-plugin-tasks-executor-0 DEBUG [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] getService bundle [com.atlassian.plugins.base-hipchat-integration-plugin-api]
I tried to update the UPM plugin to the last compatible version, testing the upgrade to 7.9.2 and 7.10.0, but the result is the same (instance stuck in "Running system startup tasks ..."
Some people faced the same issue here, but the solution is not clear enough:
Hi Alex,
You can try Clear Jira Plugin Cache, if you are using linux, try turning off SELinux and Firewall to test if this does not cause a problem.
Best Regards
MoroSystems Support
