JIRA inside an iFrame
Rahul Aich [Nagra]
July 8, 2014
HI All
We want to include JIRA dashboard /Agile burndown inside an iframe or frame in a HTML page , which we display on a large TV set on our floor. As i understand this feature does not work since jira 4.1 and atlassian has marked this bug as wont fix.
So, i want to understand from you if there is any workaround for this bug?
The link to the existing feature request is this.
https://jira.atlassian.com/browse/JRA-20988
Rahul
Christian Giroux
Being able to embed a dashboard or a walboard into an iframe would be rather luminous. Provided that the user is already authenticated from Jira prior to loading the page with the frame.
Davin Studer
December 20, 2019
This can be done now by disabling the header in the CSP that disallows it to be iFramed.
https://confluence.atlassian.com/jirakb/security-headers-in-jira-939919914.html
Matt Talaga
How do we do this in the Cloud version?
Like • adam-zurek_threatmark likes this
Davin Studer
April 8, 2020
Unfortunately, it cannot be done with Cloud as Atlassian controls the HTTP headers sent with the HTTP request.
Deleted user July 24, 2020
is there a way to share a JIRA Dashboard in a Confluence Page without showing the top menubar? :thanks @Davin Studer ?
Davin Studer
July 24, 2020
Yes, but it is a bit of a hack. In the Jira Administration -> System -> Announcement Banner you could add this.
<script type="text/javascript">
AJS.toInit(function(){
if(top != self) {
AJS.$('#header').css('display','none'); // Hide the top nav if the page is iframed.
</script>
Like • Deleted user likes this
Wow, does that work on cloud instances too?
Davin Studer
July 24, 2020
So, this would only work on server and data center instances. Cloud doe not let you embed custom script, css, or html.
Thanks for your prompt reply. Any alternative on the roadmap for this type of needs? I understand that this is hard to get for this parties, but in this case we are talking about Atlassian dashboards.
Like • Jimmy MALKOUN likes this
S
October 7, 2015
The JIRA wallboard has a bug in it that doesn't allow you to scroll issues.
Pedro Cora
July 9, 2014
Hi Rahul,
While this is not possible to achieve using the iFrame, you can use the JIRA Wallboard Add-On (https://marketplace.atlassian.com/plugins/com.atlassian.jirawallboard.atlassian-wallboard-plugin) that will allow you to display these boards on a screen.
