JIRA install error - 500
Jessica K September 8, 2014
I am installing JIRA version 6.3.4a on a virtual server.  After installation and during set up,  I am able to enter my database type/sql information and test the connection which is successful.  Once I hit the next button I receive a 500 error.  It states com.opensymphony.module.propertyset.PropertyImplementationException: SQL Exception while executing the following:SELECT ID, ENTITY_NAME, ENTITY_ID, PROPERTY_KEY, propertytype FROM jira.propertyentry WHERE ENTITY_NAME=? AND ENTITY_ID=? (Invalid object name 'jira.propertyentry'.)
Can anyone assist please?
Also, do you have to uninstall and reinstall to configure again?
Nic Brough -Adaptavist-
September 8, 2014
That often happens if you've got the database setup incorrect (You have got the wrong collation type, case sensitivity or whatever, not that you've got the wrong details in Jira).  Have a look at the application log from when you first started the new system - did it throw database errors then?
Tim Eddelbüttel
September 8, 2014
Check that your datebase user has permission on the database itself.
Register here ⬇️
